Join the Community today
Username Post: Distributor problem        (Topic#335696)
Pmullins61
Pmullins61
Loc: Frankfurt, Germany
Reg: 04-17-16
05-11-16 04:02 AM - Post#2627550
Hi
I have the stock distributor with electronic ignition on my 216.
Seems I have a problem with timing slipping, the guy at the shop fixed this problem last time, looks like its moved again as the engine is now missing. Could I sort this problem if I purchase a new distributor, if so what is the recommended upgrade
Many thanks
05-11-16 05:54 AM - Post#2627570
    In response to Pmullins61
Don't be too quick to replace the distributor just because you can. Do some diagnostic work first. That's the mark of a mechanic.
A timing error won't usually cause the engine to miss. Does a timing light actually confirm that your timing has "slipped"? If yes, check the clamp which attaches the vacuum advance to the distributor body. I'm assuming you have already checked the hold-down screw which goes through the slotted hole in the "octane selector".
Pmullins61
Pmullins61
Reg: 04-17-16
05-11-16 10:31 AM - Post#2627614
Hi Ray
The last guy who corrected the problem said he needed to tighten as when he gave it some gas the timing slipped, he said it could happen again as the the location of the clamp was difficult to reach, I am ok with him been doing my cars for a while. This is the second time its happened, I thought to replace as maybe its worn.
Paul
Pmullins61
Pmullins61
Reg: 04-17-16
05-11-16 01:25 PM - Post#2627654
Attachment: Distributor.jpg (361.41 KB) 71 View(s)
05-12-16 09:14 AM - Post#2627830
I agree that the clamp screw is difficult to tighten because it is behind the distributor. Try removing the screw and re-installing it from the other side to see if this makes it any easier to reach for tightening. If you do this, make sure to catch the nut, which will fall off when you remove the screw. Another possibility would be to replace the screw with one that has a hex head so you can use a socket wrench on it. As long as you can get a matching nut for the new screw, I don't see any reason why you couldn't use a metric thread screw approximately 4 or 5 mm diameter.
The clamp is no longer available as a separate part, so if yours is damaged beyond salvage, you may need to replace the complete vacuum advance assembly. What year is your car? The vacuum advance was redesigned for 1952 to clear the side engine mounts first used that year. If you have a 51-earlier car, the 52-later type can still be used, but you may need to rework the vacuum line in order to connect it.
If the above is unclear, please feel free to ask for any explanation you may need.
Pmullins61
Pmullins61
Reg: 04-17-16
05-12-16 12:55 PM - Post#2627881
Appreciate the feedback,
The 216 is a 1950
During the winter upgrades I added the twin Carters, replacing the Rochester, electronic ignition amongst many others, however didn't change the distributor.
This is now the third time this has happened, last time we changed the fuel pump as well as resetting the timing, seems when you go flat to the floor with gas something happens with the timing.
With the HEI Distributor from Stovebolt, does this do away with the original Vacuum, I am enough dollar into this now the 200 for a new distributor will not break the bank.
Paul
05-12-16 08:46 PM - Post#2627962
Langdon's distributor has the conventional type of vacuum advance which rotates only the breaker plate instead of the entire distributor body like the stock 216/235. It should solve your loose clamp problem, but this seems like the expensive way to fix it if you already have electronic ignition now.
Pmullins61
Pmullins61
Reg: 04-17-16
05-21-16 08:58 AM - Post#2629668
Fixed it today, was a combination of the bracket not tightened enough and one bad HT connection, so we are good thanks for the feedback
Paul
05-21-16 08:40 PM - Post#2629756
Thank you for the feedback. I am very glad to hear that you were able to fix the problem without having to replace the distributor.
Ryan53
Loc: South Dakota
Reg: 07-15-16
08-28-17 05:57 AM - Post#2705841
I am having this same issue with timing slipping, ever since I replaced the vacuum advance, am I just not getting the clamp tight enough?
1953 Chevy Belair 2dr sedan, 235 3speed 6volt
08-28-17 12:35 PM - Post#2705901
    In response to Ryan53
The clamp slipping is a problem I have never run into before seeing your post. It shouldn't need to be terribly tight because it doesn't take very much force to rotate the dist. You could check the dist for binding in the block, but that is another problem I have never personally had to deal with. Much more commonly, the dist is too loose in the block rather than too tight.
If you have difficulty getting a screwdriver on the screw head, you could try reversing it as I described in my earlier post.
Ryan53
Loc: South Dakota
Reg: 07-15-16
08-28-17 01:45 PM - Post#2705913
I can't reverse it, rear facing is the easiest way to get at it. Today I replaced the flat head bolt with a hex head bolt and a small spacer sleeve to get it away from the clamp so I could tighten it easier. I'm using my inch pounds torq wrench to get consistency. Need to test drive it a couple more times and recheck timing.
Execution time: 0.245 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:41 AM
