41 Years of Service
Username Post: treadle vac        (Topic#335512)
jaxbeachdawg
Loc: Hilliard Florida
Reg: 05-07-03
05-04-16 06:26 PM - Post#2626331
do you have any tips to replace this unit with booster and front discs,havent seen a set up to go with original power brake pedal
1957 Chevrolet 4 Door Bel Air Sedan,283 Power Pack,Powerglide,Power Brakes and Steering,81,000 Documented Miles,Proudly Driven In Loving Memory Of My Son Cory(1983-2000)
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
05-10-16 07:03 AM - Post#2627380
    In response to jaxbeachdawg
The only way to change this is to relocate the booster to the factory pedal position for manual brakes. The offset stock power booster position is too far over to the drivers side for a replacement one to fit. Typically, there is a plate on the firewall that covers the factory position and can be removed to open that spot up again.
Thanks,
Aaron @ Classic Performance
800-522-5004
jaxbeachdawg
Reg: 05-07-03
05-19-16 12:38 PM - Post#2629314
    In response to cpptech
so i would need to replace my stock power brake pedal with a non power pedal?
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
05-24-16 09:51 AM - Post#2630214
That is correct.
Thanks,
800-522-5004
jaxbeachdawg
Reg: 05-07-03
05-24-16 06:20 PM - Post#2630309
thanks
Execution time: 0.359 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:48 PM
