Username Post: 66 Impala wiper motor        (Topic#335343)
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
04-30-16 10:52 AM - Post#2625254
Hi Donny,
I am in the final stages of installing the wiring on my Impala.although I am confused about the wiper wiring.I have a two speed with the pump..I have wired it as the instructions,but right above the three wire plug there is an extra wire connection,the instructions don't say anything about it..although it shows it in the picture,but only shows it hooked up to the wiper motor,not the other end..please advise..thanks for your time.
Dave
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-30-16 07:10 PM - Post#2625390
    In response to Badboywrench
  • Badboywrench Said:
Hi Donny,
Dave
It's probably the extra blade for a T400 kickdown power lead.
Donny
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
05-01-16 08:27 AM - Post#2625468
    In response to aawtech
I don't think so..as the wipers aren't working..any other ideas?
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-01-16 09:25 PM - Post#2625637
Dave, the instructions for that set up are really clear. Take another look at what you have. The white wire is keyed 12v. The wipers are hot all the time when the key is on. Did you check for voltage on that white wire? Basically, you are switching ground. That is what the switch does. Make sure it is properly mounted in the dash. If it's hanging loose, the wipers will not work as they will never see a ground.
Donny
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
05-02-16 07:19 AM - Post#2625695
Donny,
I understand it's constantly hot and you use the ground for switching..what I don't know is what I'm supposed to hook up on that extra prong above the 3 prong plug? It had a wire before,and it worked before? That isn't explained in the instructions..
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-04-16 04:23 AM - Post#2626163
Donny,
Dave,
There is a fantastic photo on page 4 of the engine instructions 510363, as well as the assembly procedure that shows you how the build the wires for your application. As the matter of fact, it even shows the extra blade with a yellow wire on it which, as I said was the power feed for the T400 kick down harness. If you do not have a T400, that blade is not used.
With the key on, using a test light, check voltage on those two white wires at the pump and motor. You should get a light showing voltage is present. If not, the fuse is probably blown. If you have voltage there, make sure you have that copper ground strap under one of the mounting bolt to be sure the motor is grounded solidly. Next, make sure that the switch is mounted firmly in the dash. If it is not, you will not transfer internal ground to the motor and pump, and nothing will work.
Again, nothing is needed on the extra blade unless you are running a T400 trans.
Hope this helps.
Donny
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
05-04-16 04:06 PM - Post#2626314
Thanks Donny yes it does help.I have power to the white wires..the only way the wipers work, is if I ground that extra blade? It never had a T400 trani. But it did have a wire to it before I removed the old harness..this is why I thought it needed a wire going to it.and yes the picture does show the wire from the extra blade,but it doesn't show or tell you where the other end goes to...the wipers worked perfect before I removed the harness.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-04-16 06:12 PM - Post#2626340
It could be that the ground was disturbed when you unwired everything. That was why I went over that whole system for you buddy! did you get it to work? What did you find out? That extra blade is bussed to the one next to it which is the 12v feed wire. If you ground that, the wiper fuse should have blown instantly as soon as the car was turned on.
Donny
Edited by aawtech on 05-04-16 06:14 PM. Reason for edit: No reason given.
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
05-06-16 10:54 AM - Post#2626708
Well I got it to work...but only after grounding that blade? Everything else is as the instructions say..can I just leave a ground on this blade?thanks Donny
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-06-16 05:08 PM - Post#2626764
LOL. It should blow the fuse instantly. I don't get it.
Donny
Badboywrench
Badboywrench
Loc: Pinole,Ca.
Reg: 10-06-12
05-13-16 02:32 PM - Post#2628085
Sorry Donny I've been out of the state for a week..I thought it should pop a fuse..but it doesn't ....strange...
Execution time: 0.231 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:16 PM
