Username Post: Test Fitting the 427        (Topic#334971)
ptjsk
ptjsk
Loc: Northern California
Reg: 05-30-08
04-18-16 07:17 PM - Post#2622738
Hello Guys,
As I was test fitting the 427 BBC today, I come extremely close to the firewall on the drivers side.
I think I'll go ahead and "scallop" a small piece identified by the dotted marks.
Can you guy's recommend to move ahead with this, or will I encounter issues on the inside?
Thanks, Pat
Attachment: __55_Firewall.jpg (218.63 KB) 38 View(s)
Attachment: 427_in_Nomad_Drivers_side.jpg (560.5 KB) 40 View(s)
Attachment: 427_in_Nomad_Passenger_Side.jpg (520.94 KB) 38 View(s)
cnbell
cnbell
Reg: 04-14-04
04-19-16 09:56 AM - Post#2622929
    In response to ptjsk
As long as I have enough room to remove & replace the valve covers & distributor I am ok. Taking that section in a bit isn't going to cause any trouble.
The only problem would be moving it in to far could interfere with the full travel of the gas pedal.
ptjsk
ptjsk
Reg: 05-30-08
04-19-16 12:46 PM - Post#2622954
    In response to cnbell
Thanks Craig,
If I go in about 1/4" - 3/8" you think it would be ok?
Pat
cnbell
cnbell
Reg: 04-14-04
04-20-16 09:20 AM - Post#2623177
Hi Pat,
Yeah, that's not going to cause any problems.
Are you going to use a cable pedal set up or the stock hard linkage ?
You get a lot more pedal adjustment with a cable set up like Lokar.
Either way you'll be ok.
Bruces 57
Reg: 01-03-07
04-20-16 05:22 PM - Post#2623265
Hello;
Damn, thats nice! Hope it all works out.
Bruce
ptjsk
ptjsk
Reg: 05-30-08
04-20-16 05:36 PM - Post#2623269
    In response to Bruces 57
Hey Craig,
Yes I will be using the Lokar cable setup.
I went ahead and "scalloped" it out today, and it turned out real good.
Thanks for the information.
Also, Bruces 57, thanks for the nice comments!
Pat
cnbell
cnbell
Reg: 04-14-04
04-21-16 10:58 AM - Post#2623412
Chevrobert
Loc: Braintree, Ma. USA
Reg: 06-14-08
04-30-16 02:26 PM - Post#2625303
Pat,
I am NOT an engineer but I was a ship fitter.
My first thought when I saw your cut out dots
and other cuts made already,
was about the structural integrity of the firewall.
Where your marks are, is on what appears to be
a strengthening column.
You might want to get an opinion more qualified than mine about re-enforcing that area.
Good luck.
Bob
'64 Impala SS
'77 Pontiac Ventura SJ
('91 Olds Cutlas Cruiser SL)
Ain't to proud to think out loud.
ptjsk
ptjsk
Reg: 05-30-08
05-01-16 09:35 PM - Post#2625641
    In response to Chevrobert
Thanks for the information Bob!
I took out a very small portion of the firewall. It really is a small segment, so I don't think I need to worry about it too much.
Thanks again,
Pat
Attachment: Cutout_on_Firewall.jpg (265.85 KB) 23 View(s)
Attachment: Welded_piece_on_firewall.jpg (260.29 KB) 31 View(s)
ptjsk
ptjsk
Reg: 05-30-08
10-30-16 06:27 PM - Post#2659190
Thanks Bruce!
nomads
Execution time: 0.263 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:30 PM
