Username Post: 1999 blazer 4l60e hard shifts        (Topic#331729)
ironpower12
Reg: 11-24-11
12-31-15 08:38 AM - Post#2598942
W have a 1999 blazer, we drove down to florida from indiana. All was well untill we had a slow down and it began to hard shift 2n-3rd. I stopped off and checked fluid, looked low so i topped it off. I gassed up and hit the road and it shifted perfect. Then yesterday after an hr drive it began tp shift hard 1st to 2nd. After we left the beach it was fine.
It seems like it resets once we shut it down. I read some about an accumulator valvr issue?
Ive gotta head back to indiana saturday.
Senior Chevytalk Moderator
12-31-15 06:30 PM - Post#2599081
    In response to ironpower12
How many miles are on it? Check for pending codes. Transmissions are hard to diagnose with out a special scanner and checking oil pressures.
Is it a 4x4?
ironpower12
Reg: 11-24-11
12-31-15 08:48 PM - Post#2599114
155,000 its a 4x4. I have not checked codes. I do have a scanner at home
01-01-16 03:46 PM - Post#2599302
Is the 4x4 completely disengaged?
Go to any parts stores. They will scan it for free. You can buy a odbii port plugin for less than $25 for a good one. Then use a free app to read codes. Both Bluetooth and iPhone plugins are available.
ironpower12
Reg: 11-24-11
01-01-16 05:39 PM - Post#2599338
Yes it is fully disenguaged. I have bosch scanner at home. I knew i should have brought it.
01-02-16 11:37 AM - Post#2599489
I keep one of these in my console. https://www.google.com/search?q=elm21&cl ient=t...
Work great for trips or scanning when needed. I use a paid app for code reading or live data streaming.
ironpower12
Reg: 11-24-11
01-03-16 06:49 PM - Post#2599782
Thanks for the advice! when i got home i read my codes and nothing came up.
The whole way up to indiana it did not shift hard once!
I decided to go ahead and change my fluid, i am not sure which brand would be best, Pennzoil, Havoline, Valvoline or store brand?
I figure anything has to be better than whats in it now!
01-04-16 05:26 AM - Post#2599852
Most Dextron III oils will work. I stick to the same one in my vehicles, Castrol.
ironpower12
Reg: 11-24-11
01-04-16 06:34 AM - Post#2599859
ok, well i have store brand in my jeep, and valvoline in my truck. I guess ill try pennzoil in the blazer!
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
01-05-16 05:01 AM - Post#2600068
I'd use GM Dexron VI.
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
SixPac
SixPac
Loc: Evansville, IN
Reg: 02-18-03
10-26-17 05:25 AM - Post#2712210
I know its an old thread, but my 2000 Silverado has done this for years. Tranny shop told me they can solve by removing a plastic check valve that hangs up when hot and then releases when it cools down or.... replacing it with a stainless one.
Execution time: 0.598 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:12 PM
