Username Post: Rear end ratio 1967        (Topic#331607)
rls8836
Loc: North La.
Reg: 01-30-02
12-27-15 03:55 PM - Post#2598027
My camaro has a limited slip tag on the rear-end. I tried to check the ratio with chalk marks and rotating the wheel twice and counting driveshaft rotations. I came up with a 3:42. I know for a fact it is positraction. Was this third member offered in my Camaro from factory in 67?
SteveW
Loc: Shreveport
Reg: 04-24-02
12-28-15 12:39 AM - Post#2598136
    In response to rls8836
327 motor.
Standard 3.08:1
Economy 2.73:1
Performance 3.55:1
350 Motor
Standard 3.31:1
Economy 3.07:1
Performance 3.55:1
SteveW
12-28-15 09:06 AM - Post#2598175
You didn't say whether you have a 10 bolt or a 12 bolt rear. 3.42 was not offered as a factory option in either one. It is available as an aftermarket gearset for the factory 12 bolt, but not the factory 10 bolt (8.2").
If you have a 12 bolt, you probably have an aftermarket gearset. If a 10 bolt, you likely have a complete rear end swap. In that case, you will need to find out what kind of 10 bolt, because there are several different possibilities.
Crawl all over the center section until you find a casting number and a casting date code. These will be raised numbers CAST into the center section, not stamped. If you do find any stamped numbers, post those too.
SteveW
Loc: Shreveport
Reg: 04-24-02
01-23-16 11:04 PM - Post#2604127
    In response to SteveW
RPO (regular production option) L48 295-hp Turbo-fire 350-cu-in V8
(Special axle ratios)
1. 3-speed transmission -optional 3.73:1
2. Powerglide transmission-optional 3.55:1&3.73:1
3. 4-Speed Transmission -optional 3.73:1 and available as positraction axle only 4.10:1 ,4.56:1,and 4.88:1
SteveW
pdq67
Loc: Columbia, MO, USA
Reg: 08-31-02
01-29-16 07:04 PM - Post#2605330
I dearly love my 12-bolt, 3.31 posi-.
Ordered it that way.
pdq67
rls8836
Loc: North La.
Reg: 01-30-02
02-15-16 10:59 AM - Post#2608942
raycow I have a 10 bolt, the driveshaft turned less than 3 1/2 turns with 1 revolution of the tire. that's why I assumed a 3:31. Will try and jack up car and find all id info and post
rls8836
Loc: North La.
Reg: 01-30-02
02-15-16 11:05 AM - Post#2608943
    In response to pdq67
PDQ67 I've seen your car on the net, nice you have kept it this long. Would you know what rpms you run at 60,70 mph?
pdq67
Reg: 08-31-02
02-16-16 09:47 PM - Post#2609403
Sure with stock D-70/14, Redlines, that range from 25.3" to 25.5" in dia., it runs 3070 to 3050 rpm at 70 mph.
I installed my great big 9.50/14 Firestone, Town & Country, Mud & Snow tires on my car by raising it about 4" to 4.5" and my speed went from 70 mph to 82!! They were right at 29.5" in dia...
My car was still going up at 145 mph early one Monday morning trying to get back to my Mom's place to catch my carpool to go to IA when I was working on the RR as a kid back in the spring of '67.
pdq67
02-17-16 02:51 AM - Post#2609426
3.31 was not offered as a 10 bolt 8.2" ratio, but 3.36 was. That's most likely what you have.
Edited by raycow on 02-17-16 03:02 AM. Reason for edit: No reason given.
pdq67
Reg: 08-31-02
04-03-16 08:08 PM - Post#2619430
I want to say that "Steve's Nova Site" lists all the rear end options for almost everything.
Might hunt it up.
I know there is one somewhere because I looked through it through the years.
Oh, not applicable here, but don't forget about the old P/U 12-bolt rear ends..
pdq67
models916
Loc: Addison, IL
Reg: 05-28-10
04-12-16 05:11 AM - Post#2621082
Truck 12 is very weak. Small diameter pinion shaft. Works in the truck because of the larger ring gear but for performance it is just marginal.
pdq67
Reg: 08-31-02
04-18-16 08:24 PM - Post#2622743
    In response to models916
Somewhere, somebody did a write up on our car sites on the web telling how to install either 12-bolt car gears in a 12-bolt P/U housing OR the 12-bolt P/U gears in our car 12-bolt housing.
A very detailed and quite interesting install if anybody is interested in this??
I do know it caught my eye because my old '80 C/10 had 12-bolt P/U 2.76 reg's under it and I was thinking about them under my Camaro for a heck of a top-end charge vs my 3.31's!
pdq67
pdq67
Reg: 08-31-02
07-09-17 08:36 AM - Post#2699315
Sorry rls8836, my car has NEVER been posted on the web that I know of! It has been garaged for more years than I want to think about.
I was once riding to a small car show with JimM (1st Gen. Site), in his blue,'68 rag-top car. It has a white top.
If I remember right, Mark McGraw(?) from St. Lois was following along in his red Camaro and took a picture of me in Jim's car and it has been posted on the web.
Way years ago here. Probably can't find it though???
pdq67
Edited by pdq67 on 07-09-17 08:37 AM. Reason for edit: No reason given.
pdq67
Reg: 08-31-02
08-12-17 02:14 AM - Post#2703835
Back again, if not mistaken our rear end housings axle tubes have code numbers stamped on them. I want to say on the pass. side so you might look there.
Probably like about in the middle in the front???
pdq67
Execution time: 0.723 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:43 AM
