 Page 2 of 2 <12
Username Post: SBC 350 locating TDCC and aligning rotor correctly other misc issues        (Topic#331459)
Bennybone
Reg: 12-21-15
01-13-16 01:42 PM - Post#2601818
    In response to 0utlaw
Ignition Man and Outlaw - excellent plans I will follow and report back.
The issue I have with running up idle (HOT) is when I go into gear the snap on the transmission is violent, I cringe when that happens and don't know that I can live with that on a car I'd like to see become a daily leisure driver.
01-14-16 08:16 AM - Post#2602000
    In response to Bennybone
After adjusting the carb for max vacuum at idle, you still have to reset the idle speed to spec to prevent the problem you are seeing with the trans.
IgnitionMan
Reg: 04-15-05
01-14-16 10:37 AM - Post#2602043
Adjust the idle speed AS you are adjusting the fuel screws, adjusting the idle speed AFTER the screws will force you to readjust the idle mix screws, over and over again. Set idle speed first, work from there.
Bennybone
Reg: 12-21-15
01-14-16 10:59 AM - Post#2602047
    In response to IgnitionMan
What is the best resource for adjusting a Quadrajet?
I asked for an updated tech paper from Lars however he states a remanufactuered Qjet isn't tunable and to shelve it.
I'm happy with the initial carb performance with the exception of the automatic choke which doesn't seem to be functioning so I have it disabled.
In order of priority my plan is:
Install a vacuum advance stop and time the engine to its best baseline performance off full manifold vacuum.
Fix the automatic choke
Solve the temperature issue I am experiencing since I put in a thermostat and new radiator and new cap
Then tune the carb
Edited by Bennybone on 01-14-16 11:00 AM. Reason for edit: No reason given.
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
01-14-16 08:48 PM - Post#2602166
I haven't been following this too closely but if you are having temperature issues I would be willing to bet if you tune your ignition system the way ignitionman is telling you to do there is a pretty good chance your temperature issues and some other problems you are having will be solved.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
Bennybone
Reg: 12-21-15
01-19-16 04:22 PM - Post#2603369
    In response to LUVmachine
So I did a home made pin stop for 10 degrees of advance for q total of 20 at idle on manifold vacuum.
When I installed the vacuum canister the arm didn't clear the metal stop, so I uninstalled and ground down the height of the metal stop until sufficient for the arm to swing over and move the pin freely to the stop. I noticed the new distributor had a lower clearance here than another distributor on hand.
Car runs good I'm ready to fix electric choke and tune the quadrajet - still no guides for this please post a link.
Also the car still is going hot - the day I test drove it was 35 degrees and temp went to 235. Gauge still bobs between 190 and 230 for no apparent reason (like air in the system), the cap is tight the hoses tight and i tried burping the car 4 times on ramps.
models916 67
Loc: Addison, IL
Reg: 05-28-10
01-20-16 06:43 AM - Post#2603466
Disconnect the vacuum advance and set the timing on a damper tape for all in at 38 degrees, 3,000-4,000. Then work from there if needed.
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
01-20-16 09:37 AM - Post#2603481
Electric chokes are a little bit difficult to set up and rather critical on a quadrajet. If you have the butterfly too tight, you get too much gas and stumble. If it is too loose, you get backfiring, hesitation or stumble. And simply firing up the car, you only get one chance of getting it correct. SO...
Here is a simple tip. Cold engine...do not start, do not allow fast idle screw to rest on step cam of choke by putting a wedge ( tiny piece of wood works) between the throttle and hot idle screw..choke should close.
loosen choke housing and adjust the housing until the choke plate lightly closes and has some finger resistance. Snug down screws. Now remove plus wire from choke. Substitute a hot wire from the battery. You can then watch the choke action. It should open slowly and be fully open (vertical) in approximately 6 or 7 minutes. If it opens too soon, adjust it tighter. Too slow, adjust it looser. While doing this, watch the step cam to make sure it is free. Let choke housing cool off.
Remove the wood wedge you put on the throttle...reconnect your choke wire and fire it up. You can tweak the choke from there in small increments.
Bennybone
Reg: 12-21-15
01-20-16 03:17 PM - Post#2603526
Thanks for the in depth clarification.
I've connected a switch 12 volt source to the choke connection - 12.4 volt measured and when connected the voltage reads 1.86 volts.
To date the choke hasn't fluttered no matter the position.
Will running a constant 12 volt source make any difference and is the load supposed to drop when connected or did I get a bum e-choke ?
0utlaw
0utlaw
Loc: US East Coast
Reg: 09-10-02
01-20-16 03:49 PM - Post#2603533
If you do not have one, you may need to run a short wire from the other choke terminal to ground ( one of the housing screws should be good)
or verify the wire you have is connected.
Then check with meter.
01-21-16 11:24 AM - Post#2603656
If you are seeing 12.4V on the unconnected wire and only 1.86V when it is connected to the choke terminal, this means you have a lot of resistance somewhere between the switch and the choke. As a test, connect the choke wire directly to battery power and see what you get.
new in 62
new in 62
Loc: Alberta Canada
Reg: 10-13-15
10-25-17 09:53 PM - Post#2712198
Try disabling your rockers your exhaust valve could be hitting the piston stop while it is opening & that is where you will stop turning by hand but the piston stop did not contact the top of the piston try marking again with rockers disabled.I found out an easy method of centering your 2 marks lay a strip of paper on your balancer one end butted up to one mark & cut the other end off on the other mark fold this piece exactly in 1/2 lay it back on the balancer against a mark & mark the other end this will be your TDC mark.new in 62.
65_Impala
Reg: 12-29-02
10-26-17 12:11 PM - Post#2712242
    In response to new in 62
It's been a year and 9 months since the last response. I really hope he got it figured out by now.
 Page 2 of 2 <12
Execution time: 0.226 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:29 PM
