41 Years of Service
Username Post: 2 inch drop spindles        (Topic#329421)
wcoffey357
Loc: Maryland
Reg: 07-24-14
10-12-15 11:45 AM - Post#2581964
I purchased CPP 2in drop spindles with a disc brake conversion kit for my 68 impala. Once everything was installed my outer tie rods are 3 1/2ins off the ground. I wanted to know if there is a solution to this or do I have to install a set of stock spindles and cut a coil off the coil springs to achieve the 2in drop so that the outer tie rods would not be that close to the ground?
Edited by wcoffey357 on 10-12-15 11:47 AM. Reason for edit: No reason given.
Execution time: 0.204 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:12 PM
