40 Years of Service
Username Post: Glazed rotors        (Topic#329393)
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
10-11-15 01:00 PM - Post#2581766
I have the 65-70 Impala disc brakes with the large calipers, standard rotors & 8" double diapraghm booster.
The pads supplied with the kit seemed to overheat quickly & fade, so I fitted some Bendix MRD52S semi metallic pads.
The disc rotors have glazed badly & don't want to stop, particularly when cold.
I'm looking for suggestions please - are the pads too hard?
Or do I need to look at slotted rotors?
This is a big block car, so is heavy
Steve
1966 Caprice 396 496 496mkII TH400
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
10-12-15 07:08 AM - Post#2581909
    In response to Crusty66
What diameter wheels are you running on this car?
Thanks,
Aaron @ Classic Performance
800-522-5004
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
10-12-15 11:41 AM - Post#2581979
    In response to cpptech
17" American racing Torque Thrust II, so plenty of ventilation
Steve
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
10-12-15 01:15 PM - Post#2582001
Bigger Wheels are a bit harder on brakes but should not glaze over. Check for pre-load on the master. Sounds like the brake stays engaged creating a lot of heat.
Thanks,
800-522-5004
Crusty66
Crusty66
Loc: Albany, eNZed
Reg: 11-04-12
10-20-15 12:02 AM - Post#2583639
Ok, have had discs machined & fitted new pads.
Brakes not staying on.
The problem I have is very poor front brakes - if I brake lightly, the front brakes work after a short delay. If I brake heavily the front brakes feel like they aren't working at all - they feel the same as if they are overheated and fading even when stone cold. The pedal feels hard when this happens.
I have good vacuum as I have added a vacuum assist pump.
I have checked the proportioning valve warning switch, it is not showing a circuit.
When I brake lightly the pedal feels normal, a bit softer.
Is this a proportioning valve issue?
What do you think the problem is?
Steve
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
10-20-15 07:41 AM - Post#2583695
Please call 800-522-5004 ask for the Tech department. This may be easier over the phone rather then the forum. We will help figure out these issues.
Thanks,
800-522-5004
Execution time: 0.493 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:56 AM
