Join the Community today
Username Post: Power Steering noisy        (Topic#329369)
tarps
tarps
Loc: New Jersey
Reg: 10-18-06
10-10-15 01:55 PM - Post#2581521
My grandson has a 2001 MC. The PS pump had a leak and the steering was noisy. He replaced the pump today and bleed it as required. No longer have a leak but still have the noise. Any idea what causes it. Thanks, Tom
tarps
tarps
Loc: New Jersey
Reg: 10-18-06
10-11-15 03:20 AM - Post#2581649
    In response to tarps
Not being an expert I was thinking of suggesting that the noise might be caused by the steering gear or the control valve.
fbi9c1
Loc: Los Angeles
Reg: 08-07-07
10-16-15 05:10 PM - Post#2582985
Most likely you still have air in the system and possibly it is from another leak, probably a hose. It takes a bunch of lock to lock turns to work all the air out of the system. Did you do that? Did you use the specified type of fluid?
Good luck!
Jim B.
tarps
tarps
Loc: New Jersey
Reg: 10-18-06
10-19-15 04:13 AM - Post#2583432
    In response to fbi9c1
Thanks: I will pass your information on to him. I know that he jacked the car up as instructed to bleed system. He rotated less than ten rotations. Appreciate your response.
Execution time: 0.18 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:01 AM
