41 Years of Service
Username Post: Master Cylinder and Proportion valve.        (Topic#324775)
50hotrod
50hotrod
Reg: 07-25-11
05-22-15 05:42 AM - Post#2548932
I have been accumulating parts for my 50 chevy project for the last 2 years. I purchased a firewall manual brake conversion kit from Walton Manufacturing with/Master cylinder, and proportion valve supplied by CCP.
This spring these parts were finally installed. The pedal assembly from Walton fit perfect and the master cylinder/proportion valve also fit like a glove. New brake lines, rubber hoses, rear wheel cylinders, front calipers, all new. Complete new brake system from 1 1/2 years of accumulated parts.
I could not achieve a brake pedal. After inspection, I found the proportion valve was leaking from the rod that protrudes from the front of it, under the rubber cap. I replaced the ccp proportion valve. No more leaks.
I still could not achieve a brake pedal so I replaced the ccp master cylinder. I now have brakes with perfect pedal pressure.
The problem is I have a new defective master cylinder and new defective proportion valve from ccp I can not return for a refund because they were purchased in advance (accumulating parts) prior to installation. This is the first time I have encountered a problem of this nature. Is there anything we can do to rectify this problem? Thanks.
People done gone put their Bible's away
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
11-01-15 12:10 AM - Post#2586105
    In response to 50hotrod
I also had a bad master cylinder from them, I tried everything for months trying to get my brakes bled, when here on chevytalk guys said it must be a bad master cylinder.
Contacted cpp, and was told to keep bleeding.
I bought a brand new master cylinder just like it from Napa, brakes finally bled.
Contacted cpp again and was blown off.
I gave up on them at that time (what else can a customer do?)
My stuff was new, and they didn't take care of me, so that tells me they have no warranty, it's buyer beware.
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
11-09-15 07:34 AM - Post#2587694
    In response to 1965C-10
Items are always under warranty to the original purchaser. Please forward me the invoice number by email or PM and I can look into this for you. Sorry for the delay in reply; I just got back from the SEMA show.
Thanks,
Aaron @ Classic Performance
800-522-5004
1965C-10
1965C-10
Reg: 11-18-01
11-11-15 01:18 AM - Post#2588078
    In response to cpptech
I found the box but not the receipt(I have moved twice since buying my parts)
If I call and give my information can you find it that way?
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
11-12-15 08:24 AM - Post#2588362
yes, call our customer service dept.
Thanks,
800-522-5004
50hotrod
50hotrod
Reg: 07-25-11
11-14-15 11:05 AM - Post#2588762
LOL.....Well at least they responded to your post!
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
11-16-15 08:31 AM - Post#2589233
that offer was to both of you on this thread.
Thanks,
800-522-5004
Execution time: 0.211 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:40 PM
