40 Years of Service
Username Post: Hydro Boost        (Topic#319859)
itsa56
Loc: Iowa
Reg: 08-07-03
01-07-15 03:17 PM - Post#2512928
I currently have an ECI booster setup on my 56 Nomad. My questions is, can I change out the booster to a hydro boost and use the same master cylinder and proportioning valve? I drove a 57 with hydroboost and really like the pedal feel. I currently have too much travel in the pedal. The brakes work good but the pedal goes down farther then I like. Thank you for the help.
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
01-08-15 07:30 AM - Post#2513051
    In response to itsa56
Our CPP Hydra-stop units require the use of an 1-1/8" bore size master cylinder. If you have that great it will work. If your master is a 1" bore you must also buy a new, proper sized master.
Thanks,
Aaron @ Classic Performance
800-522-5004
itsa56
Loc: Iowa
Reg: 08-07-03
01-08-15 08:23 AM - Post#2513071
    In response to cpptech
The master cylinder I have is a corvette master cylinder. I guess I'll have to call ECI and find out what size it is. Thanks.
itsa56
Loc: Iowa
Reg: 08-07-03
01-10-15 06:11 AM - Post#2513485
I found out I have a 1 inch bore master cylinder. Looks like it won't work with the booster. Thanks for your help.
Execution time: 0.187 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:31 AM
