Username Post: Which motor oil to use        (Topic#319315)
MR_150
Loc: merrilville,indiana
Reg: 08-30-02
12-23-14 06:55 PM - Post#2508701
A buddy of mine recently pulled his 1982 Corvette Collectors Edition out storage after sitting about 10 years or more.Back in the day he would buy his motor oil off the shelf at discount stores.A lot has changed in motor oils since he last drove the car.The newer oils have less zinc now and he has a hydraulic flat tappet camshaft and he is concerned about flattening out a lobe.The car also has a catalytic converter and is stock.So which oil can he run that has enough zinc to protect the camshaft and not plug the catalytic converter.Thanks
wagonmaster
wagonmaster
Loc: Loganville, Ga.
Reg: 04-28-00
12-24-14 05:11 AM - Post#2508766
    In response to MR_150
Use any of the full synthetic oils for no lubrication problems. I use Mobil 1 or Chevron and my son swears by Royal Purple with their additive. Any way you go it shouldn't be a problem.
Hey T @!
Joe
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
02-18-18 02:43 PM - Post#2724788
Amsoil Z Rod oil. It is formulated for flat tappet cams. I run it in both my flat tappet equipped cars.
Execution time: 0.521 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:41 PM
