Jims56chevy
Loc: chino valley az
Reg: 11-23-04
10-31-14 03:58 PM - Post#2495107
Yes i'm looking for info, i'm about to put a 700r4 trans in my 56, right now it has the digital speedo setup, and i'm going to change ir over to the mech setup.Is there anyone here using the 700r4 with 3:73 and 29" tires/I'm trying find out what speedo gear setup i need.
thank you and have a good day.
10-31-14 04:56 PM - Post#2495121
In response to Jims56chevy
A 17 red drive gear with a 44 dark gray driven would be the closest combination. http://www.tciauto.com/tc/speedometer-gear-c alcula...
Jims56chevy
Reg: 11-23-04
11-01-14 10:36 AM - Post#2495244
In response to acardon
Thanks Bud.Bowties has calculator,that comes up with 19 and 34.So which one correct?
http://700r4.com/speedoCalc/speedocalc .shtml
Edited by Jims56chevy on 11-01-14 10:38 AM. Reason for edit: No reason given.
DECEASED
11-04-14 04:41 PM - Post#2496210
29" tires and 3.73 gears is 2594 revs/mile, so 44:17 HAS to be the right pair. Whoever came up with that 34:19 combo needs to start looking for some better stuff to smoke. If Bowtie's transmissions are as bad their calculators, they are going to be having some serious problems.
models916
Loc: Addison, IL
Reg: 05-28-10
11-06-14 06:46 AM - Post#2496592
39 driven and 15 on the output shaft will be right on the money. Small holder housing.
http://www.ebay.com/itm/TCI-Auto-880018-S peedomete...
http://www.ebay.com/itm/39-tooth-700r4-TH 350-TH400...
http://www.ebay.com/itm/39-tooth-700r4-TH 350-GM-Sp...
DECEASED
11-07-14 02:24 AM - Post#2496817
In response to models916
39:15 would be good too. That's 2600 revs/mi (44:17 is 2588).
models916
Loc: Addison, IL
Reg: 05-28-10
11-10-14 10:27 AM - Post#2497524
The 44 requires the expensive gear holder for the tailshaft.
DECEASED
11-10-14 11:55 AM - Post#2497543
I didn't realize that the 40-45 tooth gear sleeve costs more than the 34-39. If you have to buy a sleeve in addition to the gears, it certainly makes sense to go with the cheaper one.
Algoma56
Reg: 03-14-05
11-12-14 10:48 AM - Post#2498052
Yes the sleeve costs more. Mine broke at the re-builders, and we were trying to find one in town used, or swap, or whatever. Hard to find, and to buy one is more expensive. Still looking to find a cheap one, hopefully one of my buddies comes up with a barter deal.
models916
Loc: Addison, IL
Reg: 05-28-10
11-13-14 06:59 AM - Post#2498284
In response to Algoma56
Small gear version in plastic
http://www.ebay.com/itm/700R4-350-BOP-PLA STIC-SPEE...
Big gear used
http://www.ebay.com/itm/GM-700R4-TH350-Sp eedometer...
