cp sizemore
Loc: Miamisburg,Ohio
Reg: 02-12-13
10-18-14 05:55 AM - Post#2491775
Have a 50 Belair original 216 3 on tree.Bought a 235 from a 54 powerglide that needs rebuilt.T216 still runs good so I'LL drive it for now.Found a bellhousing and flywheel that was taken from a 54 truck.Casting#GM3702831 ON BH.#on flywheel is3704832.Got an engine stand so, ready to start teardown.QUESTION;Will these bolt up to my 54 235 from a car so that I can get it on stand to rebuild.Also,any other suggestions would be helpful.THANKS in advance
Began driving in these old cars...Proud to be back in"100% GOOD OLE AMERICAN STEEL" |
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
10-18-14 06:01 AM - Post#2491778
In response to cp sizemore
You can use the 216 bell housing and clutch assembly on the 235 . Make sure when you rebuild the 235 that the crank has been bored to accept the pilot bushing, as not all were. Bill
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission. |
cp sizemore
Reg: 02-12-13
10-18-14 06:10 AM - Post#2491781
In response to one4dad
Tanks for the info but,Iwant to run the 216 while I rebuild the 235 on the stand.So, I need to get another bh and flywheel to mount it.
Rustchips
Loc: DFW Texas
Reg: 02-24-05
10-18-14 06:30 AM - Post#2491787
You should not need a Bell housing and flywheel to mount the engine on a stand for rebuilding.
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Life is like a roll of toilet paper the nearer the end the faster it goes. |
2blu52
Deceased Member RIP
Reg: 03-12-02
10-18-14 07:12 AM - Post#2491794
In response to Rustchips
I kind of wonder if a cast bdll housing coud actually handle 675 pounds hanging off an engine stand. Informaiton is correct, the 216 bell housing and flywheel will fit and you do not need the bell housing to mount the engine on the stand.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON |
"19th Year" Silver Supporting Member
10-18-14 07:49 AM - Post#2491801
In response to 2blu52
My 261 spent several years on this Pep Boys stand with no adverse effects. I did prop a vertical 2X4 under the front to keep it from sagging but I probably could have gotten away without it. It's a 1,000 pound stand.
1953 210 Convertible, 261 with dual Carter YF 966S carbs, P.S., Remote Bendix P.B. Booster.
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
10-18-14 09:05 AM - Post#2491805
After I bolted the engine to the stand and before I took the weight for the hoist, I welded the brackets to the stand plate. I was leery, even with grade 8 bolts.
cp sizemore
Reg: 02-12-13
10-18-14 09:15 AM - Post#2491811
THANKS,GUYS,THINK I WILL JUST DO AS SUGGESTED AND MOUNT IT THE STAND AS IS.YOU GUYS ARE GREAT.THANKS TO ALL
DECEASED
10-18-14 09:58 AM - Post#2491823
When you eventually do the 235 swap, use the 216 bellhousing and the 54 flywheel. It is drilled for the later type clutch which is MUCH better than the 216 clutch that was used 1938-53. Btw, that flywheel is a 1-1/2 year only part and is quite scarce. l955 (2nd design) and later flywheels use the good clutch but have a 12 volt ring gear, which means you would need to use a 12 volt starter with them because of the tooth pitch difference.
BottleJack
Reg: 02-09-12
10-18-14 10:03 AM - Post#2491824
I often use a "donor bell-housings" to mount 216-235 (hi &lo psi versions) to engine stands.
The reason: the larger engine stand(s) sometimes have an odd spindly mount that fits the bell housing wider bolt pattern better then than narrower bolt hole pattern on the engines' rear.
As the motor gets stripped down to bare block ; I personally find it easier to man-handle the engine with the bell-housing still attached {because I often drop the bare engine block (or valve heads) to a "wheeled dollie" http://www.harborfreight.com/2-piece-1500-lb-capac ... to move, store, or send to engine machine shop }
Use very high grade quality made nuts and bolts ( Grade 8) on the stand-to-engine mount (replace the ones that come with any Chinese made engine stands).
Then always carefully use Xtra , ALWAYS, use an xtra prop or support to hold up the front of the engine with any stand. The long Chevy Six cantilevered weight on an engine stand is an accident waiting to happen. I cut a wooden 4"x4" with a little wood base to go under the front engine mounts (or pulley), OR use a safety strap (come-along ect) securely hung from your garage ceiling thence attached to the front of the engine.
Why the extra front support? Because someone may inadvertently lean (or add some object) on that engine and it may tip over. (I have seen it happen )
Edited by BottleJack on 10-18-14 10:26 AM. Reason for edit: added LINKS
10-18-14 10:50 AM - Post#2491835
i would not recomend bolting a bellhousing to an engine stand to hang an engine off it. it is risky to say the least. if you do not do risky things of this sort regularly, it makes it even more risky. even just the length of a staight six block makes the whole thing unstable. even if you are very careful about doing this, there may be someone else that comes along that isnt. they may come up with a great idea to (help out) and disaster strikes. aside from health and safety, bolting a bellhousing to an engine is not a cut and dried job. checking it for alignment to the crank centerline is highly recomended. a 3-d alignment check and correction will ensure smooth and proper clutch, transmission operation and life. i have seen where some people only dial the bellhousing in on a two dimensional axis. that will get you only half way there.the face of the bellhousing that the trans bolts to needs to be square to the world as well. this job can be very time consuming and tedious. its best done with the main bearings that will be used in the finished engine. some folks will say that all this is just a waste of time cause they have never done it and never had a problem...maybe they havent done enough of these to know the difference. if you put the engine in and have clutch problems, the correction will not be fun. best to git er done and know its right.
Edited by bobb on 10-18-14 10:53 AM. Reason for edit: No reason given.
173rdherd
"18th Year" Platinum Supporting Member
Loc: BLACK DIAMOND BAY(tomball...
Reg: 11-29-04
10-20-14 09:10 AM - Post#2492275
it can...for 6 years now.
94 Z-28 Ram Air
75 El Camino SS (Betty)
76 el camino (Veronica)
77 El Camino SS (Getting a 454)
58 4 dr Yeoman (Nadine)
57 4 dr 150 (Dottie)
53 4 dr tradesman (Tupelo Honey)
and they're all....
Positively Fourth Street.
2blu52
Deceased Member RIP
Reg: 03-12-02
10-20-14 10:37 AM - Post#2492288
In response to 173rdherd
That answers the question.
THOMAS JEFFERSON |
