cahartley
Loc: Central Wisconsin
Reg: 01-16-14
10-14-14 01:05 PM - Post#2490848
And am wondering as I'm laying out the carpet and need to know what's the deal at the foot feed.......is the carpet supposed to have a slit cut in it and slipped over the pedal since there is no physical connection at the pedal to the actuator?
The reason I ask is because it doesn't SEEM to have ever been monkeyed with.
Chair City
Loc: Thomasville, NC USA
Reg: 01-24-04
10-14-14 06:33 PM - Post#2490943
In response to cahartley
The pedal will easily come off of the floor bracket. It snaps onto 2 studs.
1960 Impala Spt. Cpe. Now in my son's garage |
LtFrankDrebin
Loc: Quakertown, PA
Reg: 01-25-01
10-14-14 07:48 PM - Post#2490964
The pedal should snap onto two studs that are screwed into the floor. When installing the carpet, you can feel these two studs and you just cut two small holes for them. The pedal in your picture does not appear to be the original type.
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348 |
cahartley
Reg: 01-16-14
10-14-14 09:01 PM - Post#2490982
In response to LtFrankDrebin
Thanks guys.
From what I remember of my first '59, which was a loooong time ago, the pedal seems the same and I re-discovered HOW the pedal mounts in the meantime so it was off to the races.
I THINK the worst part is done.......I have an electric heater set up to warm the interior tomorrow to help the new molded carpet settle in.
I wouldn't mind farming out THIS job either.......
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
10-15-14 06:02 AM - Post#2491035
Looking good. Please document the install as much as you can so you can share with the ones of us that has that coming up. Thanks, Lamar
59Lenoir
Loc: Phila
Reg: 02-05-04
10-15-14 08:33 AM - Post#2491074
In response to PLS
Second that. At my pace I should be doing that in the next 5-10 years.....
LtFrankDrebin
Loc: Quakertown, PA
Reg: 01-25-01
10-15-14 09:39 AM - Post#2491094
I'm not familiar with that bracket then. There should be two studs with rounded ends that the pedal is snapped on to. Just pull the pedal off and make small holes in the carpet for these two studs, but it looks like you figured that out already.
cahartley
Reg: 01-16-14
10-15-14 03:26 PM - Post#2491184
You are correct WSS.......that's just what it is.......
I didn't think this would get much attention so I will keep you posted.
I learned some tricks of the trade from my upholstery guy when he put in the headliner which are coming in handy now.
I still need some pointers and am hoping he will pay me a visit real soon.......maybe even this evening.
The carpet and floor pans were SO shot I had nothing to reference so have been looking at photos on the net trying to find out what lies where and how far.
If I get anywhere tonight I'll post more photos.......
cahartley
Reg: 01-16-14
10-15-14 06:44 PM - Post#2491242
My upholstery guy is coming tomorrow to help me out and give me some tips.
I have the carpet cut back so it lays at least.
Upholstery dude said to cut the carpet so about an inch lies under the sill plates so I have some cutting to do yet.
I'm going to have to cut a slit or two to get the carpet to lay better and glue it down but where it needs to be slit won't be noticeable but, anyway, this is where I'm at.
It's important that the front section overlaps the rear section.
cahartley
Reg: 01-16-14
10-16-14 05:35 PM - Post#2491469
My upholstery guy came over to install the interior trim that was removed when the pans were installed.
Just as well I as had matching trim pieces that were part of the interior kit I got from Ciadella's.
Upholstery dude was surprised to see how well the carpet fit.
Next........the front seat.
The new floor braces came with 8 little blocks of wood that were bolted where the seat gets bolted.
I asked Mike what was up with that and he said he'd never seen anything like that before so I pitched them and we wrestled the front seat into place and after a whole lot of jockeying around FINALLY got 7 cap screws in.
Then I got in the car to adjust the front seat and only one side would budge.......then I noticed it was trying to pull the carpet back along with it....... .......AHA........the 8 little wood blocks.......
Back to the drawing board but the front seat works now.
MURPHY........is EVERYWHERE.......
cahartley
Reg: 01-16-14
10-17-14 07:46 PM - Post#2491713
Might as well wrap this up........a few details yet but the worst is over.......
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
10-18-14 10:57 AM - Post#2491837
Great looking interior - nice work!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
gbafus
Loc: Camas, WA
Reg: 07-30-06
10-19-14 12:54 PM - Post#2492093
Cahartley, The pedal in your first photo is not the original 1959 design. It appears to be out of an earlier model Chevy. Here is a rather expensive, but VERY high quality upgrade to the original gas pedal. It fits perfectly, with no modifications. It does NOT pop off those studs like the original. You remove the studs, & a very sturdy hinge goes in their place. A matching brake pedal pad is also available. Some added "bling" for the 58-64! I put one in my '58, & was very pleased.
http://www.billetspecialties.com/pedals-and-pedal-...
George
Chevrolets previously owned:
1947 Fleetline Aerosedan
1955 Bel-Air 4 Door Sedan
1958 Biscayne 2 Door Sedan
1977 Monte Carlo
Currently own:
1957 Bel Air Sport Coupe
cahartley
Reg: 01-16-14
10-19-14 02:50 PM - Post#2492116
In response to gbafus
Thanks for that but this one is staying.......much more friendly IF one would need to remove it again which in my case is highly unlikely for a long LONG time.
It came off somewhat easier than it went back on.......I really had to mash it my foot to get it back over the studs.
On another note I got every last screw in today.......it's amazing how the door sills dress it up.......
cahartley
Reg: 01-16-14
10-19-14 03:25 PM - Post#2492125
Here are the end results.
I crawled around the trunk yesterday fitting the trunk liner.......sure is nice to have a trunk the size of a tennis court......
OOPS........hafta get the seat belts bolted down!.......
