41 Years of Service
Username Post: CPP big brake kit 65-68 info        (Topic#316606)
79loserbluebu
Reg: 07-24-14
10-05-14 06:48 PM - Post#2488928
Interested in purchasing the kit 6568WBK-P13, but have a couple questions.
Wondering what does it come with, there are no pictures for the kit. If it comes with a booster and or master, is there any way I can get the kit without them?
Second question is, it says it is to be used with stock spindles, is that with disc spindles or drum spindles?
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
10-07-14 02:26 PM - Post#2489287
    In response to 79loserbluebu
This is the wheel kit, includes rotors, calipers, brackets, bearings hubs,seals and hoses. Everything to bolt onto your stock Drum brake spindle. Disc spindles do not work as the bearing size is wrong. Booster setups are sold seperately.
Thanks,
Aaron @ Classic Performance
800-522-5004
thxalot
Reg: 11-24-14
03-24-15 11:46 PM - Post#2533791
    In response to cpptech
Can this kit be used with an original manual brake setup and manual booster without converting to power?
I'd love to get disc brakes, but don't relish the idea of swapping to a power brake booster and doing all the plumbing that would be required.
Thanks!
-Burt
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
03-25-15 07:48 AM - Post#2533850
    In response to thxalot
These work very well with manual masters on a 1" bore. Stopping power is the same either way but without a booster it requires more pedal pressure from the driver.
Thanks,
800-522-5004
Execution time: 0.239 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:09 PM
