41 Years of Service
Username Post: deep or shallow bore master cylinder        (Topic#316155)
tikiwagon
Loc: dorset, england
Reg: 04-23-04
09-23-14 08:11 AM - Post#2486019
Hi I have a 59 chevy car with a dual master cylinder and 8" single booster, I bought a 8" dual booster from you recently and wonder do i need a deep or shallow bore master cylinder for this application(it currently runs a deep bore type)I know the booster is adjustable and have the correct tool from you for doing this
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
09-25-14 11:42 AM - Post#2486605
    In response to tikiwagon
If the booster pushrod protudes past the studs then you run a deep bore. we have a part # MCDG (Master Cylinder Depth Gauge) for sale as well. You want a 1/32-1/16" gap.
Thanks,
Aaron @ Classic Performance
800-522-5004
tikiwagon
Reg: 04-23-04
09-26-14 06:17 AM - Post#2486741
    In response to cpptech
Thanks, The booster is below the studs that you supplied but it does have a screw extender that came with it, So do i use that or stick with short booster stud and spacer in M/C
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
09-27-14 07:57 AM - Post#2486975
Short pushrod and the master cylinder spacer adapter is fine.
Thanks,
800-522-5004
Execution time: 0.482 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:05 AM
