dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-22-14 03:04 PM - Post#2471050
Who makes a bracket that will work with this set-up?
Thanks in advance
Danny
1960 BelAir 4dr sedan, original 235engine,3/4cam(Patricks '),848head,Clifford intake&Fenton headers,Wayne valve&side cover,BeeHiveOil filter,Langdon's HEI set-up,3spd MANUAL OD trans, |
KaelFarmer
Loc: Eau Claire, WI
07-22-14 03:53 PM - Post#2471061
In response to dtwbcs
Patrick's used to sell an ac & alternator bracket set for our 235s. I don't who the actual manufacturer is off the top of my head. The catalog (page 9) lists the price at 119.95. This bracket set uses the standard single groove crank pulley also.
Hope this helps,
Kael
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-22-14 04:08 PM - Post#2471065
In response to KaelFarmer
funny you mentioned that. I looked in the catalog-not a good picture of it.
Anybody have a picture of Patricks' bracket?
Danny
KaelFarmer
Loc: Eau Claire, WI
07-22-14 04:24 PM - Post#2471067
I don't have a picture but I seem to recall seeing the same setup about 8 or 9 years ago from Alan Grove Components(?). My daughter is 9 already owhich is the only way I remember seeing an ad in one of my older magazines.
Kael
Panama Red
Loc: Jenison, Michigan
Reg: 08-29-10
07-22-14 05:07 PM - Post#2471076
Take a look at the bottom of this page and see if that will work for you.
http://www.streetrodbracketry.com/products.php?fir...
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
07-22-14 05:12 PM - Post#2471077
Allen Grove http://www.alangrovecomponents.com/Chevy_Six_Cylin...
Vintage Air http://www.vintageair.com/INSTRUCTIONS/Brackets /14...
Go to this link, about half way down the page:
http://www.forwhatyouneed.com/Brackets,%20alternat...
Thanks in advance
1953 Belair Sport Coupe,350/350/Fatman/Dako ta Digital/American Shifter/Southern Air/Ciadella Interiors
1967 Chevelle 396 Muncie
2010 Camaro II-SS
2011 Camaro Pace Car
2012 Tahoe |
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-22-14 05:44 PM - Post#2471086
Kael ,
Thanks 4 Alan Groves's setup.I think I will buy it.It has ALL the parts needed to install with instructions
Danny
56sedandelivery
Deceased Member RIP
Loc: Everett, Wa.
Reg: 02-26-08
07-22-14 07:25 PM - Post#2471110
You might want to check on that auction site we all know and love. I just bought a universal A/C kit for my OT truck, and saw brackets for the early sixes while I was looking. Not too sure what I'm going to have to do for a bracket; between the SWP/LWP/drivers side/passenger side combos available, mine's not there unless I buy the alternator bracket also. Butch/56sedandelivery.
53Chevy
Loc: Davenport, IA
Reg: 02-18-04
07-22-14 08:57 PM - Post#2471131
You might take a look on ebay at the brackets that davispeedequip has up for sale. I have these brackets on my 261 and have had for several years. They fit and work really good and they are of the highest quality.
53belair
Reg: 03-25-07
07-23-14 05:33 AM - Post#2471173
In response to 53Chevy
You're right. Good looking set up. The photo in the link below helps understand how they connect. The seller (maker?) says the photo is of his own 235 (55-62).
http://www.ebay.com/itm/10028-A-C-AIR-CON DITIONING...
This link is the 37 - 54 version.
http://www.ebay.com/itm/10030-1937-54-216 -235-261-...
2010 Camaro II-SS
2012 Tahoe |
usmile4
"16th Year Silver Supporting Member
Loc: Aurora, Illinois
Reg: 08-12-05
07-23-14 06:19 AM - Post#2471184
In response to 53belair
My AC unit came with brackets from Alan Groves. I had to "rework" them a bit as the fit with my water pump adapter, headers and intake just required it. The brackets themselves are well made. The Alan Groves brackets put the AC compressor above the alternator which makes it a little tight to adjust things.
I looked at the Link 53belair posted and wish I had known of these as it would put the compressor on the other side of the engine. I have always wondered how one might run A/C and a power steering, and with these brackets it looks like it would be possible.
Bill Gommel
49 chevy Styleline (Sold), 51 Styleline 2 dr Special, 235 (from a 61 truck) bored .060 over, Dual Carter/Webers, Fenton Headers, T5- 5 speed with a 56 rear end. |
Hugh in NC
Loc: In my Recliner Rockingham...
Reg: 08-01-12
07-23-14 05:07 PM - Post#2471318
I bought my A/C unit from Rainbow products but the mounting brackets came in a box marked Vintage Air. It is hard to tell from the photo below, but the alternator bracket is a spacer that goes between the block and the thermostat outlet. It holds the alternator in place. You can see the belt for the alternator goes to the a/c compressor which has a dual pulley. It fit and worked great, no problems yet. I'm on my second summer of a/c now.
53Chevy
Loc: Davenport, IA
Reg: 02-18-04
07-23-14 05:21 PM - Post#2471322
In response to usmile4
Davis has been an Inliner for many years and has been working on these bracket for a long time. They fit most applications without modifications. And you have some choices. I have my alternator up on the right side of the engine and my power steering pump up on the left side. The A/C bracket is down on the bottom left side. The reason for that is because I was thinking I might want to put a supercharger on and I wanted to have a short belt from the crank pulley to the supercharger. Because I'm not sure about the supercharger or having A/C I have neither. But, I do have the bracket mounted just in case I do makeup my mind someday.
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-26-14 09:04 AM - Post#2471933
So how do you run the hoses with the A/C on the bottom? Would I have to run them vertical then OVER the engine to the firewall?
btw: a picture is worth a thousand words
Danny
usmile4
Reg: 08-12-05
07-26-14 10:41 AM - Post#2471956
Ran my hoses through the firewall on the driver's side through a bulkhead fitting. Then routed them to the AC unit under the dash. The heater used the same opening as the stock heater valve only used a bulkhead fitting there too.
Bill Gommel
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-26-14 11:01 AM - Post#2471961
do you have a picture? How did you not run into either the carbs or exhaust
Danny
usmile4
Reg: 08-12-05
07-26-14 11:51 AM - Post#2471977
I thought I had some pictures, but I cannot find them. I will get some next week.
Bill Gommel
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-26-14 05:42 PM - Post#2472045
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-27-14 05:15 PM - Post#2472273
hugh ,
Nice picture , thanks
Danny
Hugh in NC
Reg: 08-01-12
07-28-14 06:20 PM - Post#2472614
Here is a photo of the bracket between the thermostat housing and the head. It is hard to see in the photo because it is almost invisible on the engine. It is very simple and foolproof.
Here are some photos of the AC hoses and routing. I removed the fresh air vent tube (it was rusted out on the bottom anyway) and ran the hoses to the condenser thru the front hole. I made a cover for the firewall hole and mounted the fittings on it to pass thru into the interior of the car. Inside I ran the hoses up over the steering column and over to the AC unit. The hoses are not visible under the dash.
Please disregard all the dirt on the fender and under the hood.
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-29-14 03:12 PM - Post#2472801
In response to Hugh in NC
THANKS 4 the PICS!!
Helps me see how I might have to run mine
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-29-14 05:33 PM - Post#2472824
here is what I have to work with [url=https://www.chevytalk.org/fusionbb/fbbuploads/1 406680300-lftside.jpg]
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-29-14 05:35 PM - Post#2472827
these are my firewalls. Not as clean and empty as yours
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-29-14 05:47 PM - Post#2472833
maybe go over the thermostat? Or install electric fan and go around the front above pump somehow to route the lines to the passenger side?
Attachment: pump.jpg (39.21 KB) 2039 View(s)
Attachment: front.jpg (58.88 KB) 2052 View(s)
Danny
53belair
Reg: 03-25-07
07-29-14 06:49 PM - Post#2472849
From the driver's side it would be a looong route but you could run the lines between the inner fender and the outer fender. Lots of folks do this, even on the passenger side, if they want to "hide" a lot of the clutter. Some even mount the drier in there.
2010 Camaro II-SS
2012 Tahoe |
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-29-14 07:04 PM - Post#2472854
has anybody mounted the alternator down low with the compressor on top? Just in thinking stage. not even sure that you can interchange the parts ;on alan grove bracket.
Limited hood clearance doesn't help any.
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-30-14 01:58 PM - Post#2473042
alan stated can only go one way-
Danny
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
07-30-14 04:21 PM - Post#2473084
the link above to streetrodbracketry.com was a pic of his bracket which places the alt down low and the compressor on top
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
08-01-14 06:19 PM - Post#2473639
In response to lobucrod
ok-already bought alan grove bracket....thanks
Danny
dtwbcs
Loc: Brenham,Tx
Reg: 04-19-10
07-12-16 07:37 AM - Post#2639268
Geeze, has it been 2yrs since I started this post I still haven't put A/C on my car. I think I want to try to go on the passenger side; for more room and ease of routing hoses. Misses is not happy being hot when riding along.
Danny
