Username Post: gas cap--vent or not to vent        (Topic#311744)
REBORN55
REBORN55
Loc: DeSoto, Illinois. 62924
Reg: 01-21-01
05-19-14 04:40 PM - Post#2454309
Drove the sedan delivery a little today--pulled the gas cap of to a lot of woosh---thought the cap was supposed to be vented--PO had a small hole drilled in top but I guess it wasn't working---supposed to have resealed original tank(with baffles), on a carburated engine with electric fuel pump--no return lines. do you think vent tube is stopped up--need to find it I guess or just the wrong cap. Have a locking one that is supposed to be correct---it on for now---should I just go ahead and try to find the original one or stick a rag in it. Thanks
Ken http://www.picturetrail.com/reborn55
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
05-19-14 06:43 PM - Post#2454340
    In response to REBORN55
All Chevrolet gas caps, 1960 and prior, were vented. Throw the cap away and buy a new one.
REBORN55
REBORN55
Reg: 01-21-01
05-19-14 07:30 PM - Post#2454362
    In response to Gene_Schneider
That's what I thought --THANKS
robhill
Loc: Oregon
Reg: 09-19-04
05-31-17 10:02 PM - Post#2693789
Why is it a problem if you don't use a pressure relief, or vented cap? Heat expands the gas, pressurizes tank. Then it cools and retracts. Cycle this a bunch of times and imagine what it does to the metal. If you want to simulated it, try a bending a paperclip back and forth a bunch of times until it work hardens and breaks.
1946 Chevrolet Fleetamster Town Sedan
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
06-01-17 07:02 AM - Post#2693831
I have a "Tanks" "plastic" tank in my '46 and it has a vent port on the top of the tank. I ran a length of rubber tubing from there along the filler tube to just below where the filler tube goes through the fender.
1946 Chevy Fleetmaster 4-door Street Rod
Execution time: 0.426 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:11 AM
