houndhunter22mag
Reg: 04-12-14
04-16-14 06:45 PM - Post#2445241
real quick question. I have an 05 2500 duramax and im curious what my oil pressure should be at idle when the engine is hot. i just bought the truck and the pressure seems a bit low but im not sure. thanks guys.
Suburbazine
Loc: Baton Rouge, LA
Reg: 01-12-06
04-26-14 11:39 AM - Post#2447803
In response to houndhunter22mag
FYI, the gauge cluster reading is not an accurate measure of pressure. Only way to tell is to get a physical pressure gauge on a pressure port, usually there's one on the filter housing.
2002 Tahoe 5.7L Full Forged 12.5:1 DCR
EPS Tune
Some Sort of Exhaust
A Small Cam
Heads Ported/Polished/Milled Some Thousandths
4L80E swap
Circle-D Pro III 258mm 3B Converter |
evhfan2000
Loc: Portland, OR.
Reg: 10-17-04
04-26-14 04:40 PM - Post#2447853
What's the gauge say?
Dean
65 Impala Sport Coupe
99 CK2500 4x4 7.4L Crew
03 CK1500 4x4 5.3L Sub
02 CR250R |
