 Page 11 of 15 « First<11121314>
Username Post: 2ndtime50guy --- 2 door 1950 Styleline Deluxe        (Topic#309930)
06-19-16 06:15 AM - Post#2634781
    In response to one4dad
You are doing a great job Tim!!!!!
PAragtopguy
Infrequent Contributer
PAragtopguy
Reg: 08-13-12
06-19-16 08:55 PM - Post#2634926
Great job so far! Very interesting reading.
Baseball, Hot Dogs, Apple Pie and Chevrolet!!!
2015 Spring Edition Green Flash Convertible - 811 total, one of 82 ragtops.
One more 65 Impala to build when I retire!
2ndtime50guy
"2nd Year" Silver Supporting member
2ndtime50guy
Loc: Midwestern U.S.A.
Reg: 04-06-12
06-22-16 02:59 AM - Post#2635358
    In response to PAragtopguy
Thanks guys. If this thunder goes away this morning, we'll start cleaning up the dog house and doing the POR-15 on the under side. Wife said she would help today and maybe even son, since I am trying to restore TWO 50s right now! I plan to adjust the shift linkage, install 12v generator (converted from 6), voltage regulator, and other odds and ends. Oops. now I see lightning...maybe not!
Two 1950s:
2 Door Styleline Deluxe
4 Door Styleline Deluxe
Read my Profile for a Happy Ending!
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-22-16 05:12 PM - Post#2635473
    In response to 2ndtime50guy
Yeah, rain and chances of rain all day. I stayed in and cleaned parts. Some even got painted; not many. The inner fender panels will be POR-15'd, but the hardware will just get rattle can gloss black. No need to waste that expensive paint on stuff that will cause it to peel from use; ie springs, hinges, etc. Pics:
Attachment: 20160622_094855.jpg (2.32 MB) 24 View(s)
Attachment: 20160622_113301.jpg (3.19 MB) 26 View(s)
Attachment: 20160622_155506.jpg (3.53 MB) 28 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-22-16 05:18 PM - Post#2635474
Some more:
Attachment: 20160622_162921.jpg (3.42 MB) 24 View(s)
Attachment: 20160622_194552.jpg (3.29 MB) 25 View(s)
Attachment: 20160622_194558.jpg (3.12 MB) 29 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-23-16 07:04 PM - Post#2635663
What a long, hot, crappy day. Started the day by separating the driveshaft and tranny to make sure I didn't screw up my shim job. Then putting that all back together. Moved on to installing the flywheel covers...and the holes NEVER line up...but finally they did. Then onto SEVERAL hours fighting with the shifter box, only to find out I had the spring in backwards...
Tomorrow I have my helpers coming over. We hope to wire wheel, prep, and POR-15 the inside of the doghouse, install the genny and voltage regulator, add the bypass oil filter, and anything else we can knock out. This heat is killing me! No pics today, sorry.
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-25-16 08:25 PM - Post#2636081
Another hot day in the sun. Here's where I'm at. Parking brake reinstalled, transmission filled per manual, bypass oil filter canister installed, generator and battery cables installed.
Attachment: IMG_20160625_155727.jpg (553.26 KB) 26 View(s)
Attachment: 20160625_203935.jpg (3.07 MB) 27 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 06-25-16 08:27 PM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-30-16 06:24 AM - Post#2636898
I'm a little behind on updates. I started wire wheeling the doghouse to find the thin spots. The good news is that there aren't as many as I thought, even in the inner fenders. There is one pretty bad spot. Not being a welder I'll have to call for help again. I think I can cut out and fabricate the piece though. I am also going back around the car and going through the brakes again to be on the safe side. See pics. I'm having trouble with uploads and will try to add more later.
Attachment: 20160626_130412.jpg (2.73 MB) 21 View(s)
Two 1950s:
>> My Build Thread <<
06-30-16 08:17 AM - Post#2636919
What is the doghouse? See it all the time,but don't know what it is. Know what it is on vans and trucks.
06-30-16 07:44 PM - Post#2637026
Keith, the front end, hood, fenders, inner fenders grille ETC.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
06-30-16 08:21 PM - Post#2637031
    In response to Bob_Hayden
Sorry, it might not be the correct term on a 49-54. That's just what my dad always called the front end when he worked on his '56 when I was a little kid. Am I misusing that term Bob?
Two 1950s:
>> My Build Thread <<
06-30-16 09:08 PM - Post#2637043
Thanks, Bob. Sounds right to me 2nd time.
07-01-16 07:32 PM - Post#2637246
Thats right. Tim.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-02-16 04:03 PM - Post#2637357
Not bad for my very first fabrication ever. I even got the beveled lip in there. I may just make some other pieces and save some money. This only took about an hour. Pics:
Attachment: 20160702_113617.jpg (3.76 MB) 18 View(s)
Attachment: 20160702_103956.jpg (2.01 MB) 24 View(s)
Attachment: 20160702_120930.jpg (3.61 MB) 19 View(s)
Attachment: 20160702_190509.jpg (4.5 MB) 21 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 07-02-16 04:08 PM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-10-16 07:36 AM - Post#2638872
Not much to report...just lots of wire wheeling, metal prepping, and painting with POR-15. A few set backs... The heat and humidity and a short two day trip to Dale Hollow kind of took the wind out of my sails, but I'm starting to get my work ethic back. Getting ready to order my antisqueak kit from NCA (thanks for the heads up Bruce Pearce!) and I have already ordered my first piece of sheet metal from EMS...exciting things ahead!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-11-16 04:22 PM - Post#2639170
A little progress...inner fender baffles, brackets, and trunk hardware before and after...
Attachment: baffles_before.JPG (58.66 KB) 16 View(s)
Attachment: baffles_after_por_15.JPG (53.92 KB) 19 View(s)
Two 1950s:
>> My Build Thread <<
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
07-13-16 04:42 AM - Post#2639480
Nice job on making your own patch panel. I find it very satisfying and always love seeing others forming good patches.
Just Slightly Abrasive
Edited by 40grit on 07-13-16 04:42 AM. Reason for edit: No reason given.
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
07-13-16 05:51 AM - Post#2639490
    In response to 40grit
That's quite a compliment,coming from a man with your skills!
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-13-16 02:26 PM - Post#2639578
Wow! Thanks for the compliment! I hope the driver side goes as well! It's not perfect, but for not having a bending brake and being kind of hidden, it will be OK I think. Thanks guys!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-13-16 02:29 PM - Post#2639579
Great news today! I got my first EMS panel and their catalog. I got an outer rocker for the driver side. It looks beautiful!! I would go out and snap a pic holding it up to the car but it is raining and HAILING.
Attachment: 20160713_171452-1024x576.jpg (89.37 KB) 22 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-14-16 08:28 PM - Post#2639816
Tonight we started gluing anti rattle pieces on the front end parts. I have the best wife in the world who assisted with the gluing and the clamping! She has a knack for stuff like that!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-15-16 03:26 PM - Post#2639944
I made an EXTREME amount of headway today. It's amazing what you can get done when you aren't dodging rain (and this week HAIL!)...anyway. Today I got up early, spent the morning wire wheeling the driver side fender, inner fender, and radiator support frame. After lunch it was on to POR-15 degreaser and metal prep. In between steps I reassembled the passenger fender with all the anti rattle seals and gaskets glued in place! By late afternoon I had the first coat of POR-15 on the driver fender, inner fender, and radiator support. And now, just in time for dinner, I have the 2nd coat of POR-15 on everything and my driver side metal patch fabricated, using the template from the passenger side! WOW. The wife went out and bought me hardware for reassembly. Tomorrow we coat the POR-15 with rustoleum, glue on the driver side anti rattle kit, trim the new driver side rocker panel for a temporary pop rivet fitment, reinstall the radiator, wire wheel and POR-15 the under side of the hood, and Sunday, hopefully after going back to church for the first time in months, we will reassemble the whole frontend and be done with phase one! Sound good? Pics later, time for dinner!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-17-16 03:50 AM - Post#2640169
a few pics from the last few days...
Attachment: 20160715_073203.jpg (373.92 KB) 14 View(s)
Attachment: 20160715_094243.jpg (377.98 KB) 13 View(s)
Attachment: 20160715_095211.jpg (446.24 KB) 14 View(s)
Attachment: 20160715_185329.jpg (441.55 KB) 21 View(s)
Attachment: 20160716_102214.jpg (526.64 KB) 14 View(s)
Attachment: 20160716_113617.jpg (497.09 KB) 16 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 07-17-16 03:53 AM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-17-16 03:55 AM - Post#2640170
more...
Attachment: 20160716_151415.jpg (369.67 KB) 14 View(s)
Attachment: 20160716_151427.jpg (441.44 KB) 18 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-17-16 07:50 PM - Post#2640329
Well, both fenders are now reinstalled, including inner baffles, rock shields, etc. The gaps to the front doors are pretty good, but the hood is an awfully tight fit. I tried loosening the radiator side bolts to let the fenders "breath" away from each other a bit, but it's still pretty tight. The fender height is also good and I was very careful to match the original thickness of the rubber and shims under the radiator. The top fender bolts nearest the door are set just right so that the fender and door lines are flush. I kinda wish I hadn't taken the front end all the way apart, but I really wanted to get all the rust out, paint everything front and back, and do it right. Hopefully I can find some hints in the Fisher body manual? I don't know. OH...and I fit up my first EMS rocker panel today. Great fit, although the it's not welded in yet. Some pics:
Attachment: 20160717_185728-1024x576.jpg (278.33 KB) 18 View(s)
Attachment: 20160717_182314-768x1024.jpg (185.83 KB) 18 View(s)
Attachment: IMG_20160717_212754-768x960.jpg (229.18 KB) 17 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 07-17-16 07:58 PM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-17-16 07:58 PM - Post#2640332
One more...
Attachment: IMG_20160717_212938-800x450.jpg (107.04 KB) 16 View(s)
Two 1950s:
>> My Build Thread <<
Fitzback
Fitzback
Loc: St-Hyacinthe, Qc. Can.
Reg: 01-23-08
07-19-16 07:43 PM - Post#2640723
Very good progress!!
Fitz.
La vie est belle! 1953 Pontiac Pathfinder deLuxe 2 doors sedan + Victory Vision tour
Fitz
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-19-16 07:46 PM - Post#2640724
    In response to Fitzback
Thanks Fitz!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
07-22-16 06:28 AM - Post#2641189
Front end is all back together except splash pan and bumpers. Yesterday I wire wheeled, metal prepped, and painted the underneath side of the hood. I'm a little intrigued as to how the fenders and hood can line up perfectly in the front and perfectly in the back, but yet the hood is low in the middle of the fender. More work to do I guess. Pics:
Attachment: 20160721_160638.jpg (394.66 KB) 13 View(s)
Attachment: 20160721_195755.jpg (342.78 KB) 15 View(s)
Attachment: 20160721_195952.jpg (251.72 KB) 14 View(s)
Two 1950s:
>> My Build Thread <<
PAragtopguy
PAragtopguy
Reg: 08-13-12
07-22-16 08:24 PM - Post#2641305
great work! very interesting!
Execution time: 0.321 seconds.   Total Queries: 25   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:18 AM
