 Page 16 of 16 « First<13141516
Username Post: 2ndtime50guy --- 2 door 1950 Styleline Deluxe        (Topic#309930)
2ndtime50guy
"2nd Year" Silver Supporting member
2ndtime50guy
Loc: Midwestern U.S.A.
Reg: 04-06-12
05-05-18 05:39 PM - Post#2733123
    In response to 2ndtime50guy
More pics to come later after dinner!
Two 1950s:
2 Door Styleline Deluxe
4 Door Styleline Deluxe
Read my Profile for a Happy Ending!
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-05-18 05:55 PM - Post#2733125
Attachment: 20180505_154117.jpg (3.08 MB) 23 View(s)
Attachment: 20180505_173114.jpg (3.57 MB) 17 View(s)
Attachment: 20180505_173143.jpg (2.57 MB) 13 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-05-18 06:01 PM - Post#2733126
Attachment: 20180505_193653.jpg (2.49 MB) 13 View(s)
Attachment: 20180505_193754.jpg (3.82 MB) 13 View(s)
Attachment: 20180505_194607.jpg (2.34 MB) 15 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-05-18 06:03 PM - Post#2733127
Attachment: 20180505_194620.jpg (2.74 MB) 12 View(s)
Attachment: 20180505_194128.jpg (2.55 MB) 14 View(s)
Two 1950s:
>> My Build Thread <<
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
05-06-18 05:19 AM - Post#2733157
Wow! That's some extensive and impressive body work being done. Should be a good, solid car when done.
1950 Fleetline, 350 TBI, 700R4, 3.73 posi rear Blazer axle, MII front
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-06-18 06:54 AM - Post#2733164
    In response to johnwd98
Thank you Sir! It's a labor of love. I don't know if you've read the back story, but this very car was mine in high school and college. I drove it frokm 1986-1993. It sat 5 years at my parents place and we sold it in 1998. In 2014, I bought it back from the man we sold it to. He had left it sitting in a field for many of those years! I will never make my money back on this car, but I've "won the lottery" in regards to sentimental value! It's so good to be almost done with sheet metal replacement. I hope to be done with that in two months.
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 05-06-18 06:55 AM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-06-18 11:55 AM - Post#2733191
I only worked a half day today. I need rest for a long week. Fitting is coming along fine, not as hard as I thought. I measured and drilled the body bolt holes in the new inner pan and bolted down the rebuilt rail with fresh new rubber squares, bolts, and washers. I even drilled out a broken off body bolt from its flat nut that goes inside the rail and retapped the threads to the same size! I never thought I could do that with such finesse! It all looks great! See pics!
Attachment: 20180506_123701.jpg (4.07 MB) 9 View(s)
Attachment: 20180506_141101.jpg (2.24 MB) 9 View(s)
Attachment: 20180506_141111.jpg (3.91 MB) 7 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-06-18 11:57 AM - Post#2733192
A few more...
Attachment: 20180506_141050.jpg (2.73 MB) 9 View(s)
Attachment: 20180506_141121.jpg (3.47 MB) 8 View(s)
Attachment: 20180506_142404.jpg (2.56 MB) 12 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-06-18 12:02 PM - Post#2733193
By the way, that rear cross member you see has about an 8 inch hole rotted through it on the inside. Anyone have an extra frame I could buy one off of?
Two 1950s:
>> My Build Thread <<
pm5471
pm5471
Loc: EauClaire,Wisconsin
Reg: 11-21-04
05-08-18 07:35 AM - Post#2733379
Looking at the work you have done maybe you could make that frame crossmember.
Pete
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-08-18 02:47 PM - Post#2733425
    In response to pm5471
Thanks for the compliment! I'm not sure I could handle that piece though. Maybe I could have someone weld in a thick piece of box tubing. I don't know how to stick weld heavy gauge.
Two 1950s:
>> My Build Thread <<
johnwd98
johnwd98
Reg: 09-05-10
05-10-18 05:08 AM - Post#2733575
It's not much thicker than the sheet metal your working with. Maybe 10 gauge? or less than 1/8" if I remember right. I had to repair my crossmember. I just welded in a patch, a piece of tubing the right size might be hard to find and the crossmember is built the same way your frame is. Some people call it top hat, U shape with a flat welded on the top of the U. But you probably already know that.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-10-18 12:43 PM - Post#2733619
Thanks for that! I hadn't heard of that actually. I could call my old neighbor that owns the metal shop I use and have him look under the car. He might have it in stock! Thanks for the advice!
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-11-18 07:35 PM - Post#2733740
Buttoning up the trunk floor before the tail pans...
Attachment: 20180511_192228.jpg (3.25 MB) 6 View(s)
Attachment: 20180511_201907.jpg (2.57 MB) 6 View(s)
Attachment: 20180511_210058.jpg (2.69 MB) 6 View(s)
Two 1950s:
>> My Build Thread <<
johnwd98
johnwd98
Reg: 09-05-10
05-12-18 05:47 AM - Post#2733756
If you haven't already welded in your rear floor panels, it might be easier to remove the rear crossmember now to repair or replace. The rivets can be tough to get out.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-12-18 01:36 PM - Post#2733788
Unfortunately, they're tacked in now. I have all the patches tacked in on the driver side and the rear corner is now rebuilt, fabricated, and tacked in. It's been a great weekend so far. Here are pics!
Attachment: 20180512_145422.jpg (2.89 MB) 8 View(s)
Attachment: 20180512_145414.jpg (3.2 MB) 8 View(s)
Attachment: 20180512_145436.jpg (2.63 MB) 8 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-12-18 01:40 PM - Post#2733790
A few more...
Attachment: 20180512_145429.jpg (2.84 MB) 7 View(s)
Attachment: 20180512_145408.jpg (2.98 MB) 6 View(s)
Attachment: 20180512_121315.jpg (2.71 MB) 7 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-14-18 09:24 AM - Post#2733947
Another milestone. Floor all patched, welded in, seam sealed, and painted. It's not beautiful, but it will never be a show car. Almost back on Schedule. Tail pans are next! Then the rear quarter.
Attachment: 20180513_183909.jpg (2.73 MB) 7 View(s)
Two 1950s:
>> My Build Thread <<
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
05-16-18 07:14 AM - Post#2734095
I really admire someone who can do can do this kind of extensive work. Hats off to you. And having "your" car back must be special.
It's also nice to see what my car looks like, under the skin, so to speak.
We had a 4dr '50 when I was a kid, and it's something that I've wanted for a long time.
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-16-18 06:23 PM - Post#2734136
    In response to Dave in VA
Thanks for the encouragement. I welded in the tail pans tonight and I didn't do as well as hoped. Hopefully I can fix it. Pics...
Attachment: 20180516_204925.jpg (2.66 MB) 7 View(s)
Two 1950s:
>> My Build Thread <<
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-19-18 03:58 PM - Post#2734367
Great weekend so far. Friday night I cut loose the new outer tail pan and refit it. The gaps are now better and I welded the latch pillar back in. It now locks and closes nice and solid! Today I continued welding and grinding and fitted up the new rear quarter. It fits perfectly! Right now I have it pop riveted in place. See Pics!
Attachment: 20180519_171633.jpg (2.81 MB) 1 View(s)
Attachment: 20180519_171753.jpg (2.27 MB) 2 View(s)
Attachment: 20180519_171725.jpg (2.21 MB) 3 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 05-19-18 03:59 PM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-20-18 08:25 PM - Post#2734467
Look who rolled out into daylight today!
Attachment: 20180520_165546.jpg (3.34 MB) 1 View(s)
Attachment: 20180520_165603.jpg (3.8 MB) 0 View(s)
Attachment: 20180520_165634.jpg (3.74 MB) 0 View(s)
Two 1950s:
>> My Build Thread <<
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
05-21-18 02:59 AM - Post#2734474
OK !!! She looks Happy!!
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
05-21-18 07:04 PM - Post#2734550
    In response to rcr3
I think she smiled a toothless grin. She goes to the dentist in about 3 weeks! First I have to address her "gum disease" with sanding and grinding. Fortunately no more cutting!
Attachment: 20180520_165648.jpg (3.68 MB) 0 View(s)
Two 1950s:
>> My Build Thread <<
Edited by 2ndtime50guy on 05-21-18 07:05 PM. Reason for edit: No reason given.
Execution time: 0.399 seconds.   Total Queries: 30   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:41 AM
