Username Post: 1933 chevy wood        (Topic#309129)
Reg: 03-09-14
03-09-14 10:06 AM - Post#2434204
Working on my 1933 Chevy again and looking to replace the wood with steel. Any one done this?
Loc: calgary, AB Canada
Reg: 10-07-00
01-02-15 12:19 PM - Post#2511336
    In response to gmann
Usually done on street rod Chevy?
1959 el camino 1959 delivery 1960 impala 2HDTP 1960 nomad CANADIAN 348CI AH!! 1973 ss el camino
Loc: phoenixville, pa
Reg: 11-07-04
09-30-16 06:10 PM - Post#2654236
wood is good!!!
Loc: Lebanon, Tennessee
Reg: 03-30-08
11-04-16 03:30 PM - Post#2659941
I have a 32 Chevy and would like to do the same thing. So far I have been unable to find details about it. Please post any photos once you get started!
"Charlie's 57 Chevy" I made it's very own FaceBook page please visit and "Like" hevy/214078481937849
Reg: 03-11-13
11-05-16 07:54 AM - Post#2660012
    In response to Charlie57
Had the wood replaced on my 30 3 window coupe. This was done at local hot rod shop @ 60 per hour.
All my wood was rotten and the nails were falling out. Floor board base was replaced from cowl to rear of car. A & B pilars replaced, doors rehung, doors were reinforced with steel, dash braces and winshield mounts added,rumble seat redone in steel as was all the bracing for rear panels, along with additional frame bracing. They used 2x3 steel and some 1x1.
Inside was gutted when i got the car. so this was easy decision. A wood kit is over 5K, and you still need to install.
I am still grinding welds.
The body is now solid. no wiggle from rotted wood and nails backing out.
All in all, I think the body is better with the
steel rather then new wood
Reg: 09-30-14
11-24-17 07:48 PM - Post#2715616
I did on my 32 sports coupe.
I could not afford the wood kit so i took each piece and traced it as best as I could. Some of the pieces were almost falling apart, so i did the best I could.
Wood doesnt show, so sometimes I used plywood, (very strong). The rest I used the cheaper hard wood, got some good hard from pallets!
sometimes I did not return a certain piece or 2, there was no adverse effect, no problems. I also noticed that if a piece or 2 didnt get sanded or didnt have the true shape, they fit well any way.
It really isnt an exact science, fit the best you can and move on, it all holds together well. I assembled a small section at a time so as not to disturb the whole anatomy of the skeleton.
John 3:16
32 Chev. 5 Win. Sports Coupe
Execution time: 0.217 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:31 PM
