Join the Community today
 Page 2 of 3 <123
Username Post: cbmkr56 1950 Fleetline        (Topic#308955)
50sChevys
50sChevys
Loc: Central Texas
Reg: 03-23-02
08-30-14 05:00 PM - Post#2480724
    In response to cbmkr56
Harry, really liking your car and hope I can see it finished. I remember putting a Dakota Digital in a customer's '57 Chevy about 15 years ago, and had the same little surprise of no real means of attaching it to the bezel. Don't remember what I ended up doing about it, but your statement reminded me about it.
Keep up the good work and it will be the only one in the world just like it!
Jack Jenkins
50's Chevys
50s Chevys
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
08-31-14 04:55 PM - Post#2480939
    In response to 50sChevys
Thanks i am looking at being able to drive it in the early spring,I had a setback on the 42 year old built 235 that was in it ,I am currently starting over with a 261 block now and all my old parts.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
09-24-14 11:42 AM - Post#2486353
Link to my Jaguar front install.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
10-27-14 05:39 PM - Post#2494097
More Progress, Added some ghost flames to the hood and front fenders.
Attachment: fender.jpg (358.81 KB) 79 View(s)
Attachment: hood.jpg (201.36 KB) 87 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
10-27-14 05:49 PM - Post#2494104
RH side view with the modified splash pan on the rear.
Attachment: RH_side.jpg (309.63 KB) 83 View(s)
Rear splash pan installed and ready for a bumper.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
10-27-14 05:53 PM - Post#2494105
Tried using part of a stock bumper for the rear but with the insets in the lower quarters removed a stock style bumper just did not look right. Went back to a tube style like i ran years ago only this time i did a dual tube and rolled both tubes to the shape of the rear pan.
Attachment: bumper_1.jpg (196.89 KB) 79 View(s)
Attachment: bumper_2.jpg (191.79 KB) 83 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
12-19-14 10:14 AM - Post#2507536
Now on to the engine, Using a 261 i have had and adding Serpentine . I used the longer type generator bracket. If you turn it around backwards and add the extra hole for the engine mount it will set the alternator so the belt will line up. I added an end plate and used a 10mm x 140mm bolt to get past all the bolts and brackets . Using the 55-59 front type mounts made it a little harder to get everything to fit , but it all worked out.
Steering Pump,Compressor, and Alt were from an L98 Tune port from a Corvette all new never used.
This serpentine drive will have steering and AC added, i may use a front pulley and drive the A/C from it. The Alternator power steering pump and water pump will all drive on the same belt.
Attachment: Alt_Brkt_1.jpg (163.78 KB) 60 View(s)
Attachment: Alt_Brkt_2.jpg (253.93 KB) 63 View(s)
Attachment: Alt_Brkt_3.jpg (287.58 KB) 58 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
12-23-14 09:39 AM - Post#2508600
Water pump pulley installed, Need to cut the shaft and move on too power steering mock up. Might wait till i set the engine back in the car as there are a lot of things going to be close or in the way. The long tube Clifford headers i have wrap around the alternator and i would like to mount the PS pump above the alternator.
Attachment: Alt_Brkt_5.jpg (297.72 KB) 80 View(s)
Attachment: Alt_Brkt_6.jpg (302.23 KB) 75 View(s)
Fitzback
Fitzback
Loc: St-Hyacinthe, Qc. Can.
Reg: 01-23-08
12-23-14 03:53 PM - Post#2508675
Look realy nice!
Fitz.
La vie est belle! 1953 Pontiac Pathfinder deLuxe 2 doors sedan + Victory Vision tour
Fitz
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
12-23-14 05:10 PM - Post#2508686
    In response to Fitzback
Thanks , trying to keep everything durable and nice.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-02-15 10:27 AM - Post#2511328
Now the clutch , wanted a better system than the old stock linkage, Using the original pedal setup, Here is what i came up with using a 55-57 car bell housing , 60-74 truck clutch fork and 70 truck linkage.
Attachment: clutch_linkage.jpg (274.91 KB) 70 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-13-15 05:22 PM - Post#2514452
Now to the headers, After a few times on and off the engine they have been mocked up and tig welded, I had a friend come by this morning and help hold everything while i wrapped the headers. The oil lines all cleared and i think will be fine. Might try to fire it this weekend.
Attachment: headers_oil_1.jpg (375.59 KB) 57 View(s)
Attachment: headers_oil_2.jpg (356.42 KB) 58 View(s)
Fitzback
Fitzback
Reg: 01-23-08
01-14-15 04:41 AM - Post#2514538
I love those exhaust wrapping product.
real nice!
Fitz.
Fitz
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-26-15 03:15 PM - Post#2518108
Up and Running, https://www.youtube.com/watch?v=dYoI095OEz4&a mp;fe...
Nite Dragon
Nite Dragon
Loc: Orange Park, FL
Reg: 09-20-13
01-26-15 03:56 PM - Post#2518113
looks good, sounds great too!!!
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-29-15 06:45 PM - Post#2518916
    In response to 502drfleetline
No just a piece of 1/2" hot rolled round flattened on one end and a bracket welded to the power steering end.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-15-15 02:18 PM - Post#2523555
Front clip is on and I did a prelim set on the grill, i moved the radiator down 3/4" of an inch and ahead 1/2". i was a little to close to the water pump shaft for comfort.
Will try to finish the wiring and put the hood on this next week.
Attachment: under_hood_1.jpg (359.75 KB) 53 View(s)
Attachment: under_hood_2.jpg (357.75 KB) 52 View(s)
Attachment: front_grill.jpg (298.84 KB) 54 View(s)
nauta
nauta
Loc: Shawnee National Forest
Reg: 11-04-02
02-15-15 03:11 PM - Post#2523563
That's a sweet looking Fleetline and great engine compartment. Lots of time and love showing up.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-15-15 03:46 PM - Post#2523568
    In response to nauta
Thank You
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-18-15 02:30 PM - Post#2524482
2 days and moving things here and things there , It was a little bit of a pain in the censored to say the least. As evident from the left A pillar this car had been pounded on at the factory. It looks like the firewall area across to the pillars was spot welded in the car a little bit crooked. The right hand top was out 3/8" further than the left which in turn made the center off also. This made the hinges not want to go back far enough to close the gap at the back of the hood. I modified a few parts gave the hood hinges some more adjustment room and got it real close. Lets say better than any of the other 3 cars i have out back.
Attachment: hood.jpg (277.17 KB) 55 View(s)
kensluys
kensluys
Loc: Bellingham, WA, USA
Reg: 04-18-01
02-18-15 02:57 PM - Post#2524489
That's looking real nice! Better than my car, for sure.
1951 Bel Air - January build date.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
03-04-15 06:46 PM - Post#2528191
Well the windshield is in and the back glass, normal for glass just keep working on it and it will settle in. It's a lot easier when it's 95 outside the rubber will get good and warm.
Attachment: back_glass.jpg (119.18 KB) 55 View(s)
Attachment: windshield.jpg (178.66 KB) 51 View(s)
Fitzback
Fitzback
Reg: 01-23-08
03-06-15 08:17 PM - Post#2528715
simply wow!!
Fitz.
Fitz
50 Deluxe
50 Deluxe
Loc: North Georgia
Reg: 06-17-14
03-09-15 11:51 AM - Post#2529355
Looks awesome! Nice work.
Damon
1950 Chevy Fleetline Blog
03-14-15 06:21 AM - Post#2530544
    In response to 50 Deluxe
Looking great!!!!!
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
03-14-15 10:39 AM - Post#2530603
    In response to Bob_Hayden
Trying, Sent pictures to Gina at Ciadella she and i have a couple of ideas about the interior. I was going with buckets but i think we are going back with the original bench seat.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
03-15-15 07:44 AM - Post#2530803
Found some old pics of My Chevy from about 1972-75,
Attachment: car_1975_7.jpg (149.99 KB) 57 View(s)
Attachment: Car_1975_1.jpg (283.07 KB) 51 View(s)
Attachment: car_1975_2.jpg (280.61 KB) 51 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
03-15-15 07:44 AM - Post#2530804
A Few More, Don't mind the dust our roads were and still are gravel.
Attachment: car_1975_4.jpg (264.16 KB) 52 View(s)
Attachment: car_1975_6.jpg (337.45 KB) 60 View(s)
Edited by cbmkr56 on 03-15-15 07:46 AM. Reason for edit: No reason given.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
03-29-15 02:47 PM - Post#2535160
All the glass is in and the last of the trim, beltline moulding was last i had too install.
Attachment: wglass.jpg (1.83 MB) 50 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
07-15-15 06:22 PM - Post#2562009
Done
Attachment: finish_1.jpg (441.47 KB) 72 View(s)
Cool down after the test run and speedo calibration.
Attachment: finish_4.jpg (2.17 MB) 74 View(s)
Shot of the rear.
 Page 2 of 3 <123
Execution time: 0.336 seconds.   Total Queries: 27   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:33 PM
