Username Post: TBI 350 backfires heavy throttle        (Topic#306209)
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
12-24-13 06:53 AM - Post#2410183
94 GMC TBI 350. Same truck that is hard to start in previous thread.
This truck spits,pops,backfires through the throttle body under throttle pressure. I have replaced the fuel pump with an AC-Delco. New plug wires. I have tried a different TB and distributor. Runs great going down the road at steady throttle.
I noticed with a timing light that the timing retards when you apply heavy throttle which would/should cause a backfire. Computer bad? That is all I can think of.
Any ideas?
'85 GMC C1500 SWB 355 sbc
Edited by boogie on 12-24-13 06:55 AM. Reason for edit: No reason given.
Chevytech
Chevytech
Reg: 04-25-04
12-24-13 08:38 AM - Post#2410206
    In response to boogie
Test the fuel pressure with a gauge, with the engine running.
It could have a broken fuel pressure regulator spring.
Chevytech
Chevytech
Reg: 04-25-04
12-24-13 09:05 AM - Post#2410211
Another possibility is it has a flat cam lobe.
It would be a good idea to test the compression. The head gaskets tend to fail between the center cylinders as these trucks age, and if the gasket gets very burnt through it can cause pinging and backfiring.
Double and triple check the plug wires to make sure you did not cross any.
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
12-24-13 12:52 PM - Post#2410276
  • boogie Said:
I noticed with a timing light that the timing retards when you apply heavy throttle Any ideas?
That is normal at idle. The ECM runs a very high idle advance curve, and will retard the timing significantly during heavy throttle. It will then begin to advance the timing if the throttle is held open. If it didn't you would have severe detonation/stalling.
What is the history of this truck? Did it use to always run ok and then develop this problem, or did you purchase it this way?
-91 Sierra C2500, now K2500
-81 Chev K20
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
12-24-13 04:45 PM - Post#2410326
    In response to stumppuller
No noise from valvetrain such as a loose rocker from a lobe going flat. Runs great on the road at steady throttle, give it some pedal and
it bangs pops thru the TB, back off and all is well.
It is worse in OD.
Just got it. Previous owner just installed a fuel pump. I figured he put an off brand in there so I put an AC-Delco in, same thing.
I put on a different TB, no help. I put a different(used) distributor in. I assume it is good, no change.
I have been working on these trucks a long time, never not been able to fix one until now.
Edited by boogie on 12-24-13 04:46 PM. Reason for edit: No reason given.
Allan In NE
Reg: 12-27-11
12-24-13 06:17 PM - Post#2410344
Is this just one 'pop' or is it a quick series of backfires?
Allan
Lifelong GM automatic transmission specialist
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
12-24-13 06:32 PM - Post#2410345
Ok, so it's a "new to you truck".
I had a similar issue many years ago after I assembled my 350. Started and idled fine, very light throttle input no problem, but step on it and it would backfire badly through the Throttle body. I had adjusted the valve lash too tight (flat tappet hydraulic lifters, basically stock).
-81 Chev K20
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-24-13 09:56 PM - Post#2410380
Make sure your wires are 1-8-4-3-6-5-7-2 and make sure timing is set at 0º or 2º with wire unhooked. Do a compression check, if one cylinder is low readjust the valves, while you're doing that you can make sure no rockers or push rods are bent. If it still does it after all that you probably have a wiped cam. It happens often now especially with a bigger cam since they took the zinc out of oil.
Jeff
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
12-25-13 08:31 AM - Post#2410432
    In response to Allan In NE
Allan
Quick series of backfires
Chevytech
Chevytech
Reg: 04-25-04
12-25-13 08:57 AM - Post#2410435
A quick series of backfiring when cracking the throttle is an indication of a mechanical problem like a exhaust valve that will not open which could be a flat cam lobe, a burnt intake valve, or head gaskets blown between cylinders.
With the air cleaner off, earmuffs on, run the engine and momentarily crack the throttle wide open, letting go of the throttle before the engine builds much RPMs. If it has sharp popping through the intake, this is how a flat cam lobe for an exhaust valve shows up.
The engine does not have to have any valve train noise to have a flat cam lobe.
I pull the rocker covers and run the engine to look for a rocker that does not move much.
If the rockers all move well, then you should do a compression test.
I have seen spotless engines, with no sludge at all, with flat cam lobes. Read up on the changes made to engine oil, and ZDDP for more on the suspected cause of cam damage.
Execution time: 0.25 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:01 PM
