Join the Community today
Username Post: Fuel Pump rebuild?        (Topic#297653)
Jack and Linda
Reg: 05-03-13
05-20-13 07:23 AM - Post#2347257
We would like to know if there is a rebuild kit for the combination fuel/vacuum pump for a 1954 235 Chevy Bel Air. Car has been sitting for about 10 years. When we tried to start the engine, it would run and would stall for lack of fuel. Any suggestions about finding a rebuild kit, or should we replace the pump with another type of pump that doesn't have the glass chamber on it. We want to keep it as original as possible.
05-20-13 07:40 AM - Post#2347264
    In response to Jack and Linda
Not to give you a bad time on this, but I would suspect 10 year old gas in the tank and lines before I would suspect the pump.
Here's how you can tell: Disconnect the inlet line from the pump. Hold your finger over the inlet port while a helper cranks the engine. Can you feel suction? If yes, connect a piece of hose to the inlet and put the other end of the hose in a can of fresh gas. If the engine runs now, your problem is elsewhere.
Jack and Linda
Reg: 05-03-13
05-20-13 12:03 PM - Post#2347346
Thanks for the tip, Ray. It runs well when fuel gets to the engine. We will try as you suggested and will let you and the forum know what happens. Jack and Linda (It's really Linda's restoration, I'm just the gopher)
pearljam724
pearljam724
Loc: SW Pennsylvania
Reg: 01-27-14
03-11-16 05:56 PM - Post#2614717
I've never seen rebuild kits available. I agree, that's unlikely to be your pump. Unless, it's clogged with contaminants. Mine is original and works fine. I too wish rebuild kits were available, mine is missing the filter screen. I believe it likely deteriorated.
http://i420.photobucket.com/albums/pp282/pearljam 7...
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
03-19-16 04:37 PM - Post#2616431
    In response to pearljam724
Try this guy for rebuild kits.
http://www.classicpreservation.com/fuelpumpkits.ht...
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Fitzback
Fitzback
Loc: St-Hyacinthe, Qc. Can.
Reg: 01-23-08
03-24-16 07:06 PM - Post#2617563
    In response to Original58
Jeff
I worked with him, great service and knowledge.
Fitz.
La vie est belle! 1953 Pontiac Pathfinder deLuxe 2 doors sedan + Victory Vision tour
Fitz
Execution time: 0.243 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:32 PM
