Username Post: 1991 GMC STALLS WHEN SLOWING DOWN        (Topic#295021)
PaPa T
Reg: 03-19-13
03-19-13 11:12 AM - Post#2327705
i HAVE A 1991 GMC 5.0, I'VE CHANGED ABOUT EVRYTHING BUT THE EGR VALVE. IT STARTS AND IDLES FINE AND RUNS DOWN THE ROAD WELL BUT WHEN I SLOW DOWN IT STARTS TO LOPE, LIKE ITS NOT GETTING ENOUGH GAS, AND USUALLY DIES. I'M ABOUT TO GO CRAZY, PLEASE HELP
Pacgas
Loc: Minden, nevada
Reg: 03-18-13
03-19-13 04:34 PM - Post#2327798
    In response to PaPa T
I just had a very similar a problem with my 88 k1500 with a 5.7. 350 automatic .
My truck would run fine until I slowed down, such as at an intersection where I would come to a stop, the truck would feel like it is going to die and I could not step on the throttle to keep it idling it would very quickly kind of surge then die. By surging I mean from normal idle rpm to dead stop, so it was trying to stay running but to me it felt like it was loading up.
I replaced the (iac) idle air control valve and all is well, in fact it never idled so smooth. If you end up replacing the iac, please note the instructions. Mine stated I was to drive it at speed of 40 mph for the computer to learn the iac values. I did not drive it at that speed as I live close to work but it did acquire the values without problems anyway.
Timothys Chevy
Timothys Chevy
Loc: Fredericton, New Brunswic...
Reg: 09-24-03
03-19-13 08:48 PM - Post#2327868
    In response to Pacgas
You might have a sticking torque converter clutch? That condition makes it feel like driving a stick shift, but not depressing the clutch when you stop, and it stalls the engine.
Its really common on the old 3 speed FWD transaxles.
~~Timothy~~
1984 Chevy Citation 2.5
2009 Pontiac Vibe AWD
1993 Buick Park Avenue
2001 Pontiac Sunfire GTX
PaPa T
Reg: 03-19-13
03-20-13 09:31 AM - Post#2327986
I changed everything but the EGR valve, I didn't get any instructions I'll driving it to the store and back to see if it helps. thanks
Adam144
Loc: Puyallup WA
Reg: 03-16-13
03-22-13 07:47 PM - Post#2328678
how is your oil pressure? If it goes to low it will cut the power to the fuel pump
Chevytech
Chevytech
Reg: 04-25-04
03-23-13 08:41 AM - Post#2328756
    In response to Adam144
It is common to see this written but it is not the way these TBI trucks are wired.
When the engine has oil pressure a redundant circuit supplies power to the fuel pump. This circuit goes through an oil pressure sensor/sender. This circuit is independent of the fuel pump relay.
This is very easy to test:
If you pull the fuel pump relay while the engine is running it should keep running. If it dies the oil sender or its wiring is bad or the engine lacks oil pressure.
If you unplug the oil sender while it is running it should keep running also. If it dies the fuel pump relay or its circuit is bad.
PaPa T, if you think the EGR may be the problem, disconnect and plug the vacuum hose to the EGR valve and take it for a test drive.
chevrolet_kelowna
chevrolet_kelowna
Loc: Kelowna BC
Reg: 11-23-07
03-24-13 12:16 AM - Post#2328980
    In response to Chevytech
My 1991 GMC 2wd 350 took me over a month of troubleshooting figure out why are 10 minutes of warming up it would want to sputter out just like yours. After tuneup, timing, fuel pressure checks. we unplugged the egr valve and found the huge mystery problem. Ran great without it. Grabbed one the next day and never a problem since.
(I forget now whether you unplug it and plug the line with like a golf tee or what I don't remember but it involved just unplugging it and waiting for it to warm up and sputter but never did it again.
PaPa T
Reg: 03-19-13
04-05-13 12:35 PM - Post#2332940
    In response to chevrolet_kelowna
Thanks guys, it was the EGR valve. Changed it and it's running like a champ.
Chevytech
Chevytech
Reg: 04-25-04
04-05-13 05:58 PM - Post#2333013
You’re welcome, and thank you for letting us know what fixed it.
Belairebabe
Reg: 02-08-14
02-16-14 12:56 PM - Post#2427354
Have a similar prob but all the suggestions have not cleared the prob. 91 chev p/u, 350, auto,, idles fine on start up, runs down the road,, sputters and tries to die and then stalls on braking, almost like a vacuum leak,, tested all lines, hoses and parts dealing with vacuum and found no leaks but when engines starts to act up it's like the brake booster is robbing the motor of vacuum. Have replaced everything except the o2 sensor ( have changed egr and valve, iac, tps ,knock sensor ) have done ether test on all vacuum parts and am now severely frustrated,, any other ideas???
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-16-14 01:38 PM - Post#2427366
    In response to Belairebabe
Welcome to ChevyTalk. What's your fuel pressure?
Greg
Greg
'00 Explorer XLT 4.0 V6 Auto
Execution time: 1.522 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:41 PM
