 Page 2 of 2 <12
Username Post: links to help you find parts        (Topic#28812)
ghustler
Loc: Southern Indiana
Reg: 09-06-04
Re: links to help you find parts
12-10-06 03:37 AM - Post#194191
    In response to grumpyvette
Quote:
AFTER YOU LINE UP YOUR MARKS AND INSTALL GEAR THEN ROTATE YOUR CRANK ONE REVOLUTION AND THEN DROP THE DIST. IN - AT THAT POINT #1 IS FIRING""
That is one of the most helpful statements a person could tell somebody!
Why don't they include that in the directions?????
1976 Stingray, 350ci, 4 speed, dragstar rims, 4s & 8s, Holley 600cfm double pumper, Professional Products polished Cross wind intake, Comp Cams 474 lift, 276/284 duration specialty cam, long tube headers, FLOWMASTERS,
vetteman2007
Reg: 07-29-07
07-29-07 04:09 PM - Post#1219481
    In response to rockind78
how about parts for 87 corvette , automatic. It's stock for now
" Turn Your Bottom Breather Into A Ram Breather "
C4orceCorvette.com
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-14-07 07:23 AM - Post#1230865
    In response to vetteman2007
ignition component manufacturers
http://www.performancemarket.com/ignition.htm
oil pan manufacturers
http://www.performancemarket.com/oilpan.htm
brakes
http://www.performancemarket.com/brakes.htm
cranks
http://www.performancemarket.com/cranks.htm
exhaust
http://www.performancemarket.com/exhaust.htm
clutches
http://www.performancemarket.com/clutches.htm
pistons
http://www.performancemarket.com/pistons.htm
TECH SUPPORT LINES
Holley
Performance Products provides award-winning technical support via phone Monday through Friday, 8AM to 5PM CST @ 270 781-9741.
Lunati
technical support is availible by phone Monday through Friday 7AM to 5PM CST @
662 892-1500.
ERSON
http://www.erson-cams.com/AskTechForm.aspx?BrandID...
http://www.erson-cams.com/pdf/Chevrolet.pdf
CROWER cams
http://www.crower.com/misc/contact.shtml
CRANE CAMS
http://www.cranecams.com/
DART
http://www.dartheads.com/
BRODIX
http://www.brodix.com/
please call us at 479-394-1075 for technical support
TRICKFLOW
http://www.trickflow.com/emain.asp
EDELBROCK
If you need to speak with an Edelbrock technician by phone, please call 1-800-416-8628 from 7:00am to 5:00pm, Monday-Friday, PST.
ENGLE CAMS
http://www.englecams.com/index.php
Tel: (310) 450-0806
Fax: (310) 452-3753
ISKY CAMS
http://www.iskycams.com/
phone: 323.770.0930
fax: 310.515.5730
AIR FLOW RESEARCH
http://www.airflowresearch.com/
28611 W. Industry Drive
Valencia, California, USA 91355
tel: 877-892-8844
fax:661-257-4462
DEMON CARBS (Barry Grant Incorporated)
http://www.barrygrant.com/
Phone: (706) 864-8544
Fax: (706) 864-2206
ARIZONA SPEED/MARINE
http://azspeed.stores.yahoo.net/c4col981.html
MSD IGNITIONS
http://www.msdignition.com/
TECH LINE: 915-855-7123
Shafiroff Race Engines
http://www.ultrastreet.net/
Toll Free: 800.295.7142 • Phone: 631.218.7530
Ohio Crankshaft
5453 SR 49 S
Greenville, OH 45331
Toll Free: 800-333-7113
Local: 937-548-7113
Fax: 937-548-4603
http://www.ohiocrank.com/enginekits.html
http://www.kevko.net/ (KEVKO OIL PANS)
915 North Orient Street
Fairmont, Minnesota 56031
(507) 238-9633
(800) 770-3557
STEFS OIL PANS
http://www.stefs.com/stefsindex.htm
Stef's Performance Products
693 Cross Street
Lakewood, NJ. 08701
Phone ( 732 ) 367- 8700
fax: (732) 367-8793
MELLING OIL PUMPS
http://www.melling.com/
Customer Service: 517-787-8172 ext: 125
MOROSO
http://www.moroso.com/default.asp
call 203-458-0542, 203-458-0546
MILODON
http://www.milodon.com/index.asp
Telephone
Phone: (805) 577-5950
Fax: 805-577-7540
KB PISTONS
http://www.kb-silvolite.com/index2.php
1-800-648-7970
ARP
(BOLTS/STUDS)
http://www.arp-bolts.com/
800.826.3045
REED CAMS
http://www.reedcams.com/
770.474.6664
J&E PISTONS
http://www.jepistons.com/
714-898-9764
SCAT CRANKS
http://www.scatcrankshafts.com/
310 370 5501
Schneider Cams
http://www.schneidercams.com/
(619) 297-0227
(TOOLS)
http://www.goodson.com/
800-533-8010
http://www.quartermasterusa.com/
847-540-8999
hays clutches
http://www.haysclutches.com/
216.688.8300
A few of MY favorite parts sources
http://www.survivalmotorsports.com/
248) 438-6900
http://www.dougherbert.com/
1-877-497-2787
http://www.jegs.com/webapp/wcs/store...10001_10002...
1800-345-4545
http://www.summitracing.com/
1800-230-3030
http://www.midwestmotorsportsinc.com/
1800-262-5033
Edited by grumpyvette on 11-05-07 04:13 PM. Reason for edit: No reason given.
muddin_wolverine
muddin_wolverine
Reg: 06-16-08
11-01-08 11:41 AM - Post#1554725
i cant believe i hadnt read this yet!
'87 chevy k10, 454, 10in susp, 3in bod, 42in tsls, 4speed/np205
'05 R6
'90 s10, P.O.S.
conceptone
Loc: Georgia
Reg: 01-20-10
06-10-10 01:25 PM - Post#1928075
We're here to provide pulley kits/systems should anyone need them. Concept One is a national solution for all pulley systems, crate engines and engine kits. We offer the best possible quality with hands-on customer service before, during and after your purchase.
Car pulley systems
 Page 2 of 2 <12
Execution time: 0.778 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:50 PM
