jel1957
Loc: Sugar Land, Texas
Reg: 01-01-04
08-18-12 11:49 AM - Post#2260632
I want to raise the rear of my car by roughly 1". What re the thoughts on load levelers versus air shocks? Also, with or without a shock bar (floor is in good shape). Tanks for the advice in advance.
This
Forum is Sponsored by
CharlieC
Loc: Flower Mound, TX,
Reg: 03-27-02
08-18-12 12:48 PM - Post#2260644
In response to jel1957
Most load levelers go in between the axle and the frame, resting on top of the plate which connects the axle/leaf springs/u-bolts together.
Given the Tri-5 Leaf Springs and hence the plate are underneath the axle, don't know what kind of load leveler you would use. Air Shocks pumped up would ride pretty rough. If you want to permamently lift the rear, you could get some re-arched springs, which would again, affect overall ride quality.
You could also just use longer shackles on the stock springs.
Charlie
'74 K5 Blazer 4x4
'09 Avalanche LTZ |
Big T
Loc: Simi Valley CA
Reg: 04-14-06
08-18-12 02:02 PM - Post#2260668
I would very much suggest a shock bar. They are inexpensive insurance for something that is marginally safe or unsafe depending on how you look at it. EZ to install.
Check out our sponsors site-----CPP
Tom
Docjim
Reg: 01-11-07
08-18-12 03:00 PM - Post#2260678
Put these on mine and raised it a bit over 1 inch. The ride was great and handled a bit better also.
08-18-12 04:13 PM - Post#2260711
In response to Docjim
If you use either a coiover assist shock or an air shock, you need a shock crossmember to hold the load. Our cars are pretty bad about breaking up the trunk floor in the shock mount area even with regular shocks.
jel1957
Reg: 01-01-04
08-18-12 04:21 PM - Post#2260714
Docjim - what kind of shocks are those - I was looking at the Monroe load levelers (58510)?Thanks
Docjim
Reg: 01-11-07
08-18-12 06:40 PM - Post#2260750
I believe thats what they are. Not sure about the part number but I know they are Monroe.
jel1957
Reg: 01-01-04
08-19-12 06:10 AM - Post#2260870
Thanks - that is what I am looking at
CharlieC
Reg: 03-27-02
08-19-12 07:37 AM - Post#2260898
When you mentioned Load Leveler, I thought you were talking about Load Leveler Air Bags.
I would also heed the advice of others on the shock bar as probably most everyone on this board has had cracked mounts on the floor.
Charlie
'74 K5 Blazer 4x4
'09 Avalanche LTZ |
Tabasco
Loc: Parker Co., Texas
Reg: 06-04-03
08-19-12 12:53 PM - Post#2260975
In response to CharlieC
probably most everyone .n this board has had cracked mounts on the floor.
Not me! I've had air shocks since 1984. I put them on because in the past I used my '57 as my tow car to tow a #5000 trailer. Maybe I'm just lucky.
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
08-19-12 02:26 PM - Post#2261000
In response to Tabasco
Mine has had them since 1984. No cracks either. I just removed them when I installed new shocks.
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-19-12 04:07 PM - Post#2261032
In response to 57tim
My 56 Delivery has SEVEN leaf, rear leaf springs, AND coil wrapped overload shocks (it rides fine). I have a shock bar I have'nt installed yet, but the floor looks fine, so I may not put it in. I have seen a lot of tri fives with damaged shock mountings; it makes me wonder what condition roads they were driven on. Butch/56sedandelivery.
08-19-12 04:40 PM - Post#2261045
Having had a busted up trunk floor and no rust, it makes me wonder how you guys with load levelers and air shocks were so lucky!
I guess it works both ways.
nstlga
Loc: Colorado
Reg: 12-01-05
08-20-12 08:21 PM - Post#2261544
In response to Rick_L
I also ran air shocks in the stock location for over 20 years. No cracks. Now have gas shocks in the same locale. Went to 5 leaf new springs. Got the lift I wanted and a needed stiffer ride.
| He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line. |
This
