Revolta
Reg: 07-25-11
08-18-12 11:15 AM - Post#2260622
Wondering if anyone has pics of installing and connecting the SS RPM Tach.?
My stock tach hasn't worked in a long time and before removing it from the column, I thought I'd see before pics of where the wires are being connected to, for the sake of reference.
Thanking everyone in advance
1963 Impala SS - Manual 4 Spd.
327 / 202 heads
95% Stock |
Edited by Revolta on 08-18-12 11:15 AM. Reason for edit: No reason given.
doubleE
Loc: Eagan MN
Reg: 06-02-03
08-18-12 12:30 PM - Post#2260642
In response to Revolta
I'm a bit curious, you said it's a stock tach mounted on the column on your 63. 61s and 62s had factory column mounted tachs but 63s, like the 64s had their factory tachs mounted to the dash directly above the column.
So, if your 63 truly has a column mounted tach, it's not stock/factory. That said, these and after market tachs typically had 3 wires, 4 if you count the instrument light. A + pos battery, a - neg ground, and a a wire that connected to the distributor side of the coil.
If you have a modern HEI ingnition, they have a "tach" terminal to use.
Eric
| Proud owner of
My Blue 62
Impala SS |
Richard Martin
Loc: Davis Islands, Florida
Reg: 06-12-03
08-18-12 01:30 PM - Post#2260652
1963-64 factory tach location:
http://www.google.com/imgres?q=1963+chevy+4 09+tach...
Chevrobert
Loc: Braintree,Ma. USA
Reg: 06-14-08
08-18-12 04:11 PM - Post#2260710
In response to doubleE
Do you know which wires go where on the tach?
Bob
1964 Impala SS 327 4 Forward Gears & 1 Reverse
See the USA in your Chevrolet.. |
doubleE
Loc: Eagan MN
Reg: 06-02-03
08-19-12 03:43 PM - Post#2261027
In response to Chevrobert
I'm still trying to figure out what tach you have... one like was pictured in Richards link or a column mounted tach?
Eric
| Proud owner of
My Blue 62
Impala SS |
Revolta
Reg: 07-25-11
08-29-12 11:55 AM - Post#2264430
So, so sorry for the delayed response. My Tach of course, is located on the dash, exactly as Richard's image he linked to.
327 / 202 heads
95% Stock |
Chevrobert
Reg: 06-14-08
08-29-12 12:19 PM - Post#2264440
Mine Also!
Bob
