Username Post: whats wrong with this?????        (Topic#285750)
helrazr3
Loc: chelsea mass.
Reg: 06-15-04
08-17-12 09:16 PM - Post#2260477
so im putting my interior back together installed the headliner pkg tray sail panels rear side panels and rear seat is set in place. there are two problems the rear arm rest sections sit to low on the floor there is a gap where it meets the seat side trim. and overall there is a big gap between the sides of the seat and the side panels you can see the space in the pics im looking for ideas these are all the same parts that came out of the car. i have a small block of wood holding up the back side or the rear arm rest panels. so what do you think the problem is???????
im on a highway to hell
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-18-12 08:08 AM - Post#2260586
    In response to helrazr3
There is a vertical clip on the floorboard. In the pics the armrest are to the outside of the clips whereas they need to go inside of them.
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-18-12 08:11 AM - Post#2260587
    In response to aghaga
A screw goes through the armrest into the clip to hold it up in the correct place.
helrazr3
Loc: chelsea mass.
Reg: 06-15-04
08-18-12 08:12 AM - Post#2260588
does the clip lock into the arm rest? the piece on the floor is just a straight piece of metal so im not sure how it locks in
helrazr3
Loc: chelsea mass.
Reg: 06-15-04
08-18-12 08:24 AM - Post#2260591
ahhhh ok i see the funny thing is that they dont have a screw hole in them thats why i didnt think it was the right thing to do thanks.
helrazr3
Loc: chelsea mass.
Reg: 06-15-04
08-18-12 05:55 PM - Post#2260740
my next question would be where the top of the lower armrest meets the upper piece and the seat trim piece in the rear it just seems to be floppy with no support if you were to lean your arm on it the piece will sag out and pull away from the side of the car
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-19-12 07:00 AM - Post#2260885
Do you have the two screws installed in the front of the arm rest. I think mine was stable when the rear was attached with a screw to the floor tab and mounted by the two front screws.
helrazr3
Loc: chelsea mass.
Reg: 06-15-04
08-19-12 05:28 PM - Post#2261057
yes i do have the front screws on. i think what the problem may be is that when we recovered the rear seat we didnt use the preformed cushion i just couldnt see spending 250 plus oversize shipping for it we used 2 inch foam and 1 inch bating over it and i think it made the seat too "puffy" the covers where real tight to get on and as a result i dont think the sides stick out as much as they should leaving a gap on either side between the arm rest and the seat. every other seat ive ever seen sits tight up against the arm rest so i think i answered my own question after looking it all over again.
Execution time: 0.101 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:46 AM
