Username Post: Holley Flow and Injector off time data        (Topic#285436)
al72
Loc: Michigan
Reg: 11-05-08
08-11-12 05:01 PM - Post#2258236
Does anyone have information about the Summit Racing SUM-240042, 42 Lb fuel injectors ? I bought a set of these ( SUM-240042 ) on 14 June 2010 from Summit. I have been told these are the exact ones Holley is now supplying with their new MPFI systems. The question I have is this. I'm not sure to use the OLD Injector or NEW Injector Off Time data from Holley's data sheet for their fuel injectors. Since I bought these injectors 14 June 2010 they could be the old ones or the new ones I think. Holley data sheet states that 42 lb Injectors sold with HP and Dominator systems(2010+) are the new injectors. The same Holley data sheet states that 42 lb Injectors sold with Commander 950 Systems ( up to early 2010) are the old injectors. I am running a much older Commander 950 Pro with all the updates. How can I determine which ones I have ?
Danny Cabral
Danny Cabral
Loc: Ellington, CT
Reg: 11-03-04
08-11-12 05:18 PM - Post#2258248
    In response to al72
  • al72 Said:
Does anyone have information about the Summit Racing SUM-240042, 42 Lb fuel injectors ? I bought a set of these (SUM-240042) on 14 June 2010 from Summit. I have been told these are the exact ones Holley is now supplying with their new MPFI systems. The question I have is this. I'm not sure to use the OLD Injector or NEW Injector Off Time data from Holley's data sheet for their fuel injectors. Since I bought these injectors 14 June 2010 they could be the old ones or the new ones I think. Holley data sheet states that 42 lb Injectors sold with HP and Dominator systems(2010+) are the new injectors. The same Holley data sheet states that 42 lb Injectors sold with Commander 950 Systems (up to early 2010) are the old injectors. I am running a much older Commander 950 Pro with all the updates. How can I determine which ones I have ?
You started another thread about this?
What's wrong with continuing with your previous thread?:
The Summit Racing fuel injectors, are the "new" injectors; use the "new" values!
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires
Execution time: 0.113 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:16 PM
