Username Post: TBI 454 Build - 50 State Legal        (Topic#285421)
JCampbell
Reg: 05-12-12
08-11-12 11:29 AM - Post#2258137
First post...howdy everyone. I hear this is the place for solid GM tech, so I hope to get some straight answers.
Looking at building a TBI 454 for my C30 crew cab dually. I don't want a hot rod, but I do want to up the HP/torque numbers a bit for towing and general 1-ton abuse. However, I want something that will yield reliability and longevity. I was browsing over at TBIchips.com and I ran across this build:
http://tbichips.com/Jim454.htm
Seems like a solid platform, but I'm curious about the heads on this build. Specifically, will I still be able to run 87 octane fuel? Also, anyone have any educated guesses on what the MPGs might look like on such a combination? I was getting somewhere in the neighborhood of 10.5-11 MPG on the stock set up w/ a TH400, 4.11's and 225/75/16 tires. Not looking for Prius-like numbers, but certainly don't want to decrease from the stock MPG numbers.
-Jason
Senior Chevytalk Moderator
08-11-12 12:58 PM - Post#2258169
    In response to JCampbell
Welcome to the site. I'm going to move your post over to the Performance section. BB builders give you advice on adding power to your current 454. Or do you plan to rebuild?
'96 GMC Jimmy LS
JCampbell
Reg: 05-12-12
08-11-12 08:42 PM - Post#2258308
It's a total rebuild.
-Jason
Execution time: 0.062 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:59 AM
