Username Post: Removing Rivets        (Topic#285404)
MrBadWrench
Loc: riverside, ca. usa
Reg: 04-27-01
08-10-12 11:39 PM - Post#2258023
Fellas,
I need to remove the rear shackle perches on my 51', so total of eight rivets. I managed to get one side off, but those rivets put up a fight. Does anyone have tips or a secret?
I grind off the head, drill a small hole and start hammering away using a drift punch. Is another way?
08-11-12 04:25 AM - Post#2258047
    In response to MrBadWrench
Thats the way I did mine. Sorry.
usmile4
Loc: Naperville, Illinois
Reg: 08-12-05
08-11-12 05:05 AM - Post#2258051
    In response to Bob_Hayden
I found if I used a cut off wheel first to get most of the head off, then hit it with the grinder.
Bill Gommel
Panama Red
Panama Red
Loc: Jenison, Michigan
Reg: 08-29-10
08-11-12 07:11 AM - Post#2258083
    In response to usmile4
I borrowed an air/impact gun from a friend that owns his own repair shop. He had a chisel bit and a punch bit. Worked like a champ to remove the 18 rivets holding the transmission x-member in place on my car.
Jon Hansen
My '41 Chevy blog
Blog #2
Nailheadv8
"8th Year" Platinum Supporting Member
Loc: Gardena, CA
Reg: 09-05-07
08-11-12 01:07 PM - Post#2258173
I just finished this project,
and I feel for you pal.
I used a cutting disc to slice a slot in the rivet head, and air chisel easily cut the heads off.
A cleanup with a grinder.
I drilled a small hole and then used a titanium
"step drill" to enlarge it. (do not drill through ).
A punch on an air chisel pushed them out.
The work will be worth it, stay strong.
A PROUD MEMBER OF THE BABY BLUE T-SHIRT BROTHERHOOD
MrBadWrench
Reg: 04-27-01
08-12-12 02:32 PM - Post#2258521
    In response to Nailheadv8
thanks for the input fellas.
sounds like, there is no short cut to removing these things. who ever designed these cars, designed them to last!
Loc: Ellijay, GA
08-12-12 02:44 PM - Post#2258526
They were designed to last ... that is why we can still work on them today, 60 years after leaving the assembly line.
Can't say that for the Citation or Vega ... not too many left to be worked on !
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
08-12-12 08:27 PM - Post#2258649
    In response to bobg1951chevy
I miss my Citation
I hit the head with the grinder until it's flush, then air chisel them out. I've done more than a few on this car that way.
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
MrBadWrench
Reg: 04-27-01
08-12-12 11:48 PM - Post#2258672
    In response to davidchristopher
air chisel sounds like the way to go, except i don't have one. looks like, i will be using the old 3lb hammer and some elbow grease.
50chev1067
Loc: New Jersey
Reg: 03-31-12
08-13-12 09:51 AM - Post#2258777
Fellas, Newbee with a question on the rivits. Once that you have removed the rivit/bracket, what are you using to reattach it? I have been refraining from removing mine because I havent found any replacement rivits. Thanks
usmile4
Reg: 08-12-05
08-13-12 10:59 AM - Post#2258800
    In response to 50chev1067
Why are you removing your if you are just going to reattach them?
Bill Gommel
50chev1067
Loc: New Jersey
Reg: 03-31-12
08-13-12 11:36 AM - Post#2258815
Some of them are rusted (deformed) after clean up. I have concerns about strength.
NWMO 52 Chevy
NWMO  52 Chevy
Loc: Northwest Missouri
Reg: 11-10-10
08-13-12 01:25 PM - Post#2258856
50chev,
Simply replace the failed rivets (or those you are concerned about) with the same diameter grade8 bolt.
Chris
davidchristopher
davidchristopher
Reg: 08-02-09
08-13-12 01:36 PM - Post#2258859
I couldn't imagine doing ANYTHING on my '51 without a compressor and a suite of air tools. Put that on the top of your christmas wish list!
The '51 Chevy Blog
Execution time: 0.097 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:32 AM
