Username Post: 3 Steps Forward and 2 Steps Back        (Topic#285389)
2ndtime50guy
2ndtime50guy
Loc: Midwestern U.S.A.
Reg: 04-06-12
08-10-12 04:13 PM - Post#2257938
I had a fun day. I decided after getting the engine running last week to reattach the radiator with new hoses, add coolant, and run the engine a few minutes longer to get the oil circulating so I could do a few oil changes. I want to start out with thanking Bob Hayden for walking me through some tests over the phone again.
First, we unhooked the oil gauge at the engine and cranked it with no spark to make sure the oil pump worked. CHECK! Then we reattaced gauge tube and coil wire and removed valve cover. I taught my wife how to start the car and I checked for oil flow from the rockers. CHECK!
Next I went to the store and got new hoses, radiator hose grease, and antifreeze. I enjoyed a pleasant rain (3rd time this week!) from the porch while I cut the new hoses. Hooked 'em up when the weather stopped. Just for the time being until I get my new alternator, I hooked up my old generator (JUST TO ACT AS A SPACER FOR THE OLD BELT--IT'S NOT WIRED UP!!!!!!!!!!) I set the belt tension per the shop manual, hooked up my gas can, powered up the car, and ran it for a few minutes.
After a few minutes, I noticed antifreeze misting off the belt which eventually became a steady stream! I learned lots of great things from Bob today and had a lot of fun doing them, but it appears that the bushing or seal around my pulley shaft in the water pump is shot. It began leaking from under the pulley like a seave.
The good news is that all my hoses are nice and tight and even my temporary cardboard gasket I made for the water outlet doesn't leak! In a few weeks we hope to tow the car to school and have the automotive teacher and class build new fuel lines and install a new gas tank, rebuild the brakes and master cylinder, rebuild the carburetor, and change the water pump and some gaskets. Hopefully I'll be able to get plates and take it for a drive in October or November.
I can't wait!
Is it possible to change the bushing or seal on that pulley shaft or should I just get a new water pump?
I drove a '50 from the day I got my license thru college! Sadly, we sold it when I got married. I recently got the chance to buy the same car back from the man I sold it to; but the deal fell through and now I own a nicer one: 4 Dr Styleline Deluxe!
mahlmann
Loc: Sunnyvale, CA
Reg: 01-20-11
08-10-12 05:08 PM - Post#2257953
    In response to 2ndtime50guy
That sounds more like 3 steps forward and a brief pause. You're making great progress!
Good luck with it!
Mike Ahlmann
Sunnyvale, CA
53belair
Loc: Ellerslie, Georgia
Reg: 03-25-07
08-10-12 05:49 PM - Post#2257964
    In response to mahlmann
When you digress to 2 steps forward, 3 steps back you'll be in my company.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-10-12 06:39 PM - Post#2257971
    In response to 53belair
Thanks guys! This next week is a real "catch 22". I love working on the car and learning how everything ticks, but I'm a school teacher and we go back Monday. So, I can either keep the car at home and maybe do one little project a month and not get to drive it until next summer, or I can take it to school and have the auto class do a lot of it and maybe drive it before the snow flies. Here's a thought; maybe I should keep it at home until late November, tow it to school and have them do work over the winter since I won't take it out then, AND it will have a roof over it's head when it snows. (I don't have a garage.)
Oh well. I'll figure something out.
davidchristopher
davidchristopher
Loc: Saint George, Ontario, Ca...
Reg: 08-02-09
08-10-12 07:22 PM - Post#2257982
And when you learn to walk with your shoes on backwards, you'll be in mine. :D
1951 Chevrolet Styleline Special. (350 4 Muncie '55 Driveshaft CE crossmember Heidts Mustang II front suspension, 3:10 Posi)
The '51 Chevy Blog
08-10-12 07:30 PM - Post#2257984
    In response to davidchristopher
Sounds like you have a plan Tim. Good Luck!! I am here for ya buddy!!
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-10-12 08:53 PM - Post#2258000
    In response to Bob_Hayden
Thanks again Bob!
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
08-10-12 09:14 PM - Post#2258003
Tim, think back a little. I remember when you said "school is out now and I can work on the car." If I'm not mistaken you've got a lot done. this sumer. I think Mike is right, just a pause.
If you've got Bob H. in your corner come out for the next round.
Johnnie
Johnnie
John 3:16
08-10-12 09:59 PM - Post#2258011
Lots of good progress. I would get a water pump from a parts house.
1996 Chevy Monte Carlo
2002 Dodge Dakota Quad Cab
usmile4
Loc: Naperville, Illinois
Reg: 08-12-05
08-11-12 05:12 AM - Post#2258053
Tim, I would get a new water pump and keep it at home for a while and drive it some. And start making a list of the things the class can do. then take it to school when the weather starts acting up (inside for the winter, cheap labor, tools and lift probably) Can you work a deal to have access to the shop after hours , weekends, and days off-I would have made that deal in an instant when in the first stages of working on my cars!
Come to think of it, maybe the class would like to learn how to wet sand! I have a car that could use lots of cheap labor!
Bill Gommel
2blu52
Reg: 03-12-02
08-11-12 06:12 AM - Post#2258066
Just purchase a new pump. They are reasonably priced and can be obtained at least on an overnight basis from most parts houses. NAPA had one in stock. Sounds as if you are keeping som ekind of schedule and will be driving the beast in short order. To check oil flow I remove the distributor, use a cut off flat screwdirver shaft inserted in the oil pump and run it with a 3/8 " electric drill. I have a spare engine on a stand and do this a couple of times a year and then rotate the crank by hand after oiling down the cylinders.
THOMAS JEFFERSON
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-11-12 06:47 AM - Post#2258080
    In response to 2blu52
Thanks for the great advice everyone. If it's ok with the auto teacher's schedule, I may just do that...take it up over the winter. I guess the water pump isn't the end of the world. It was just a bummer to get antifreeze all over everything that had looked nice and shiny a few minutes earlier.
I'm not sure about after hour and weekend access to the garage. I have a key that may work, but liability concerns could override that. In answer to 2Blu52, Bob actually mentioned that cut off screw driver and drill under the distributor trick, but told me the other way too since I was afraid I wouldn't get the distributor back in right, lol.
I'll talk to the local stores about that water pump. How would I go about testing the thermostat inside the return outlet? Do I just make sure it isn't frozen? That's all I saw in the shop manual.
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
08-11-12 07:04 AM - Post#2258082
is your engine a 216 , if so I will give you a used water pump, I took my 216 out of my 51 last october and it is still attached to the block, glad to give to you for a spare, as I had no issues with it, no leakage. contact me at travelerbill@bellsouth.net to make arrangements!!, Bill
Bill Wilson - 51 styleline Deluxe 2 door three speed , fentons and offy 2 carb manifold - is now a 235
Also a 1950 Chevy 2 door styleline deluxe, great patina , no running gear
2blu52
Reg: 03-12-02
08-11-12 07:29 AM - Post#2258086
Thermostats are cheap, but if you want to test one, put a pan of water on the stove,read the temperature range of the thermostat of the face of it and place it in the water, turn on the stove and borrow the wifes candy thermometer, if the thermostat is working it should start to open at a temp slightly lower than the temp shown on the face of and fully open when it hits its designed heat range.
THOMAS JEFFERSON
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-11-12 09:03 AM - Post#2258106
    In response to one4dad
Thanks Bill! You are too kind! I'll email you so we can figure out a way for me to pay the shipping!
And, thanks 2Blu for the help on the thermostat! What a clever way to look at it and see if it works! Awesome!
I just got done cleaning up my "shop" (which is my basement) so I can start prioritizing whatever comes next. I basically have everything in separate stacks all around the perimeter.
The stacks: Heater and ducts I plan to rebuild this winter, bumpers/chrome, stainless, interior mouldings (metal), upholstery panels, backseat, and misc. I boxed up all the old junk that I no longer need as well.
I don't know why, but I feel compelled to save everything "for reference", even rusty nuts and bolts that I've already found perfect matches for...:)
Edited by 2ndtime50guy on 08-11-12 09:06 AM. Reason for edit: No reason given.
08-11-12 12:20 PM - Post#2258160
I tried to rebuild my water pump and the problem I had was locating the bearings. I didn't try to locate a seal, but since seals are standard items, it shouldn't be that hard. (BTW, I didn't try very hard to locate the bearings either--I'm sure I could have ordered them from a bearing house, or even NAPA.
2-28s313233
2-28s313233
Loc: DFW Texas
Reg: 02-24-05
08-11-12 12:23 PM - Post#2258162
Keeping all the old parts, including bolts and screws until the car is completly finished is a excellant idea.
Cleon
1928 Chevy touring
1942 Chevy Sport coupe
1949 Chevy Sport coupe
1954 Chevy Bel Air HTP
1970 El Camino
1971 Monte Carlo
Loc: Ellijay, GA
08-11-12 02:09 PM - Post#2258187
For the small price for a t/stat, why test at all? Replace it with new, your baby deserves "new".
2blu52
Reg: 03-12-02
08-11-12 02:20 PM - Post#2258191
    In response to bobg1951chevy
Aw schucks, you missed out on a training session of how to reinstall a distribitor.
THOMAS JEFFERSON
08-11-12 08:19 PM - Post#2258300
LOL He didn't miss out 2blu52! I told him and thats when he decided he needed another way!! LOL LOL
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-12-12 07:45 AM - Post#2258390
Yeah, I'm already in over my head. Parts coming off engines with gears that have to line up upon return scares me. I've heard horror stories about installing the fuel pump too! My brother in law was a pretty good mechanic and he didn't even like doing those. He said his boss had some sort of trick where he packed something with heavy grease in order to act as a third set of hands to hold up the "finger" (linkage, armature--not sure what it's called) as it went back in. It all sounds like "lock picking" or "safe cracking" to me, lol.
08-12-12 07:52 AM - Post#2258395
Fuel pumps not hard to put on at all. Just remember to tighten the bolts evenly so you don't break an ear off. Hardest part for me now would being able to breath while reaching over the fender to get down in there to it!!! LOL LOL
2blu52
Reg: 03-12-02
08-12-12 08:11 AM - Post#2258400
Your brother in law was probably working with a V-8, fuel pump installation on the 216 inline 6 is far different. Two fuel connections and two bolts,Shazaam it is off. to install just reverse, however you may want to place a finger in the hole in the block, and by HAND rotate the engine until you feel the high spot on the cam move out of reach. Then install the pump moving the lobe on the cam means you do not have to install the pump against the pressure of the pump lever riding on the high spot of the cam. As along as you are doing that consider placing an inline filter between the fuel tank and the pump.
THOMAS JEFFERSON
Edited by 2blu52 on 08-12-12 08:14 AM. Reason for edit: No reason given.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-12-12 11:21 AM - Post#2258455
Man, you guys make it sound easy! Someday, I'll give it a try but I want to have someone there that has done it, just in case.
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
08-12-12 12:31 PM - Post#2258478
"3 steps forward, 2 steps back". That's the "Rockstar shuffle!!!"Over on the HAMB, 49-54 Chevys are refered to as "Rockstars",but don't ask me why; I don't guess it's caught on here on CT. Butch/56sedandelivery.
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-12-12 01:22 PM - Post#2258498
Well, if that's the case, I like having a "Rock Star". There's just something about them!
2blu52
Reg: 03-12-02
08-12-12 04:38 PM - Post#2258573
If you wear Bob Hayden down, give me a private e mail any time.
THOMAS JEFFERSON
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-12-12 07:03 PM - Post#2258624
Thanks 2Blu52! I don't think Bob is wearing down any, but I'll take you up on that some time!
08-12-12 07:47 PM - Post#2258637
LOL
2ndtime50guy
2ndtime50guy
Reg: 04-06-12
08-21-12 07:05 PM - Post#2261868
Well, I finally got an evening after school to put on that nice donor water pump that one4dad sent me! It is nice and tight with no leaks! Many thanks one4dad! Just email me and let me know how much I owe you for shipping. Me and my neighbor worked until dark, so I flipped on the parking lights so we could see while the engine ran. And that's when we noticed...my passenger side parking lens is half full of WATER from the good rains we got last week. UGH...it's another THREE STEPS FORWARD AND TWO STEPS BACK, LOL!! I spent about 6-8 hours rebuilding those foolish canisters with new gaskets, nuts, bolts, and lock washers. I even "made" a tiny 7/16 wrench that would fit inside the cannister to tighten those down! Now I have to pull the grill again and take it back down in the "workshop" for a few days. Oh well, I have a fully functional cooling system! The car runs nice; we ran it for about 10 minutes. It sounds like its "missing" every once in a while, but not bad. I know it needs a carburetor rebuild next. Then we'll go over the brake system, get a new gas tank, find a good alternator, make the new bracket, get insurance and plates, and she should be able to make it around the block!
Edited by 2ndtime50guy on 08-21-12 07:06 PM. Reason for edit: No reason given.
Execution time: 0.108 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:05 PM
