tarps (7)
Username Post: Rear Axle not centered        (Topic#285322)
Ol Dirty T
Loc: Michigan
Reg: 01-10-09
08-08-12 07:09 PM - Post#2257311
I rebuilt my rear suspension with new poly bushings. When I reinstalled the axle I had a difficult time connecting the panhard (track) bar. I had to use a tie down strap to pull the axle over slightly to get the panhard bushing to slide over the stud on the axle. With p275/60/R15s on the rear, I have a 1/4" clearance on the left and 3/4" on the right. I know I'm going to have to trim the wheel wells slightly to gain some clearance but I'd like to center it up first. Any ideas? Is it normal to have this variance from left to right? If I can center it up, with some trimming, I can get about 3/4" on each side. Enough?
454SS66
454SS66
Loc: Elmira, NY
Reg: 06-23-09
08-08-12 07:55 PM - Post#2257329
    In response to Ol Dirty T
You could get a Global West adjustable Pan Hard bar.
Global West Panhard bar
With that you can center your rear end perfectly. I have one on my car and like it.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
08-08-12 08:03 PM - Post#2257336
the rear ends come offset about 1/2 inch.i made me an adjustable panhard bar to center the rear end in my 62.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Ol Dirty T
Loc: Michigan
Reg: 01-10-09
08-08-12 08:15 PM - Post#2257341
    In response to 454SS66
I was just looking at those! Trimming the fender lip though is free. My rear springs are original and they do sag to the left where I have less clearance. I probably should replace those first and then see. This thing is nickel and diming me to death!
SS540
SS540
Loc: Down in Texas
Reg: 03-29-03
08-09-12 05:34 AM - Post#2257430
Welcome to the nickel & dime club. It's really the $5 & $100 club.
Wayne & Sherri Scott
59 Biscuit LS3 Restomod
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
08-09-12 06:13 AM - Post#2257446
    In response to SS540
I also used an adjustable panhard bar from UMI. I was able to get the tire clearance exactly the same on both sides. It makes all the difference when running oversized tires.
Johnny
1965 Impala SS
505/4-speed/4.30
models916
Loc: Addison, IL
Reg: 05-28-10
08-09-12 07:42 AM - Post#2257469
    In response to Johnny468
Rear end moves Left to right as it goes up and down. Might check that with the springs removed.
ss3964spd
ss3964spd
Loc: Fairfax, Va
Reg: 12-21-00
08-09-12 08:05 AM - Post#2257480
    In response to models916
Yup. Anytime the PHR moves from being horizontal it essentially gets shorter and pulls the rear to the left as it swings through its arc.
Definitley get it sitting level first. Then, with the weight of the car on the springs measure that the rear is centered in the frame - it needs to be fairly close to track straight. It might actually be that the rear is centered but the body is sitting wrong on the frame.
Dan
Dan
Jays 65 Super Sport
Jays 65 Super Sport
Loc: Canada
Reg: 01-03-11
08-09-12 12:17 PM - Post#2257554
    In response to ss3964spd
That's good to know when I reinstall mine
Ol Dirty T
Loc: Michigan
Reg: 01-10-09
08-09-12 06:16 PM - Post#2257696
It could be a little cocked on the frame. 1/4" doesn't seem like much until you start rubbing the sidewall off a set of new BFGs. I think I'll be trimming to gain some clearance.
Execution time: 0.098 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:32 AM
