of this great
online community.
steeler2666
Reg: 08-08-12
08-08-12 03:59 PM - Post#2257253
I have a 1991 k2500 with a 4l80e trans. Intermittently it will stick in second gear & not shift. Not even manually. I pull over & shut off the engine for about a minute, restart & it shifts perfectly. I changed all 3 solenoids, both speed sensors & throttle position sensor. Trans is not worn out. I feel this is an electronic input problem. Please someone help!
Allan In NE
Reg: 12-27-11
08-08-12 05:32 PM - Post#2257283
In response to steeler2666
The next time it does it, pull the codes and let's see what's going on.
It's going into limp mode for some reason.
Allan
| Lifelong GM automatic transmission specialist |
