Username Post: '55 Belair won't start bad ballast resistor?        (Topic#285313)
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-08-12 03:36 PM - Post#2257249
I've had my '55 belair for 30 years, and I have never had a problem with it not starting. All of a sudden it won't start. The 265 engine cranks over, there is spark going to the plugs,and it's getting gas, but it won't start. I've installed new plug wires, new plugs,new coil, and even a new distributor. Could it be a bad ballast resistor? I'm at my wits end here. Please help!
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-08-12 04:08 PM - Post#2257259
    In response to aftershock222
Correction: I did not replace the ignition coil yet. The spark does look kind of weak.
08-08-12 05:08 PM - Post#2257279
Try putting a jumper wire directly from the + battery to the + coil and crank it. The ballest resistor is bypassed while your cranking, but the jumper will bypass all the wiring.
57 2dr HT (restoring)
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-08-12 05:41 PM - Post#2257288
Thank you, I'll try that.
Doc Fillem
Reg: 04-17-12
08-09-12 07:54 AM - Post#2257474
Has it been running since you replaced all the above? If not, it could be your timing, distributor not installed correctly or plug wires not in the correct location. Just some other things to check. If it's got spark and gas it should run, unless......
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-09-12 04:22 PM - Post#2257666
    In response to Doc Fillem
Well,the ballast resistor bypass didn't work, so I again pulled one plug and ground it out. It fired up when I cranked the engine. I pulled another plug, and it was soaked in gas. But how can it be soaked in gas if I never depressed the gas pedal? Could the carb be flooding the engine on it's own? I forgot to mention that the old distributor shaft was very hard to turn almost frozen. I thought that a new distributor would have solved the problem. The car had been in storage for the last 25 years,but like I said before it always started faithfully.
08-09-12 08:00 PM - Post#2257733
Yes, after sitting that long, the needle and seat in the carb is gummed up and letting gas past, to flood the engine.
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-09-12 08:10 PM - Post#2257736
    In response to acardon
Thank you,I'll check it out.
DavidTX
DavidTX
Loc: Killeen, TX
Reg: 08-11-03
08-11-12 06:45 AM - Post#2258078
Have you checked your dwell or measured the gap of the points?
55 Shaker
55 Shaker
Loc: north central IL.
Reg: 03-13-06
08-11-12 10:27 AM - Post#2258123
222 maybe you could put your location in your profile, and a willing fellow CT'er near you might be willing to come by and give you a hand. JAT.
C57Heaven
C57Heaven
Loc: Ohio USA
Reg: 08-02-00
08-17-12 04:09 PM - Post#2260365
    In response to 55 Shaker
do the smell test on your oil in the pan too. If you've got a lot of flooding it will denigrate your oil and cause bearing damage.
As soon as you make the (flood)repairs change your oil.
Peace,
John H.
55 BA 2dr Sed owned since 1979, sold 6/1/09;
1957 Conv (starting to restore)
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-28-12 07:30 PM - Post#2264220
    In response to C57Heaven
Hi,everyone sorry for the delay. I changed the oil, dried out the spark plugs,reinstalled the distributor and set the carb float. The car started right up and purred like a kitten. I set the timing and dwell then took her for a drive. She ran great. Well, today it's back to square one. I had just pulled out into the street when the engine began running terribly underpowered. I floored the pedal and no response.The engine then died. Now it's like before. It won't start for nothing. The fuel pump previously showed 4.5 lbs. Could the glass bowl fuel filter have something to do with it? I heard sometimes they cause vapor lock. Could it still be that ballast resistor? I miss my car. Please help!
08-28-12 07:36 PM - Post#2264222
I suspect that the carberator float needle is still leaking and flooding the engine. It's fowling out the plugs so it won't start.
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
08-28-12 07:53 PM - Post#2264226
I'm seriously thinking of rebuilding or replacing the carb.
aftershock222
Loc: Bakersfield,Ca
Reg: 10-18-07
09-04-12 06:37 PM - Post#2266608
Acardon, you were right. I pulled off the carb, and it looked like a lake in there. I never taught a carb could leak so much gas without the engine running. I changed the oil, and put on another carb. All is good now. Thanks to all!
Execution time: 0.109 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:38 AM
