tarps (7)
Username Post: Torque for 7/16 bolts for front backing plates?        (Topic#285308)
mahlmann
Loc: Sunnyvale, CA
Reg: 01-20-11
08-08-12 03:00 PM - Post#2257234
Does anyone know the torque spec for the four 7/16" bolts that secure the front brake backing plates? This is for '54 brakes (that are going into our '50 tin woodie. They sure were hard to remove1
Mike Ahlmann
Sunnyvale, CA
CrazyKliev
CrazyKliev
Loc: Manitoba, Canada
Reg: 07-30-10
08-08-12 03:34 PM - Post#2257248
    In response to mahlmann
I didn't know either but I found grade 5 and 8 torque spec charts on the net that I've been using. http://www.portlandbolt.com/technicalinformation/ bolt-torque-chart.html . If that doesn't work, you can find other charts by typing in bolt torque specs.
1951 Styleline De Luxe 3Spd
1952 Styleline De Luxe Power Glide
mahlmann
Loc: Sunnyvale, CA
Reg: 01-20-11
08-08-12 04:10 PM - Post#2257260
    In response to CrazyKliev
Thanks for the tip. I looked at your site and a few others and it looks like:
78 - 85 dry and
60 - 68 oiled (foot-pounds)
After being on there for ~58 years they required a LOT more torque than that to break loose.
Mike Ahlmann
Sunnyvale, CA
Execution time: 0.086 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:23 AM
