Username Post: power brake failure        (Topic#285199)
Cutlass442
Reg: 06-04-05
08-06-12 10:49 AM - Post#2256400
I have a 56 BelAir with Power disk brakes. I had the car parked up hill yesterday. When I backed down, the rear end was high and when I got back level on the road, my brake pedal went to the floor and no brakes. I kept pumping the pedal and the brakes returned to normal? Brake fluid does not appear low, but could use a really small top up. Any ideas on why this would happen or if this is indicative of a more serious problem?
Thank you
1956 Chevrolet Bel Air, 4 door Hardtop 1972 Cutlass 442 Holiday Coupe, 455 Ram Air w. his & her Hurst shifter 2002 Trans Am Collector Edition, Convertible, 6 spd,
mikeski
mikeski
Loc: Massachusetts
Reg: 03-26-05
08-06-12 02:08 PM - Post#2256447
    In response to Cutlass442
I think your master cylinder croaked. You have brakes when you pump them up, but they fail when you step on them.
MikeSki
http://community.webshots.com/user/sroski
Edited by mikeski on 08-06-12 02:24 PM. Reason for edit: No reason given.
Cutlass442
Reg: 06-04-05
08-06-12 03:32 PM - Post#2256473
    In response to mikeski
I don't feel safe driving it anymore, so I think you are right - I am going to book it in for a complete inspection.
Thanks so much.
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
08-06-12 06:31 PM - Post#2256555
Good idea. My brakes(master cyl) died during the winter and the brakes reacted just as you described. Master was leaking between the MC and booster.
57 Bel Air 2dr Ht 327 700r4 http://www.picturetrail.com/tmneid
Execution time: 0.072 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:32 AM
