of this great
online community.
silver72
Reg: 08-05-12
08-06-12 09:44 AM - Post#2256379
Front drivers brake stuck on, had to temporary fix to get truck home. Removed brake line from master cylinder and plugged port (to front brakes)Only back brakes were working, drove for awhile and same front brake stuck on again. How did front brake get brake fluid to lock back up?
IBGM
Loc: Silvertown, Ma.
Reg: 12-03-03
08-06-12 01:55 PM - Post#2256441
In response to silver72
Did you plug the line you took off? I could see the pad rubbing a bit, heating things up and maybe the fluid expanding with the heat, causing it to move in a bit. Driving with just back brakes is scarey! I wouldn't do that for long!
