navygunner08
Loc: New London, CT
Reg: 02-13-11
08-05-12 07:59 AM - Post#2255924
I know this gets asked alot but I cannot decide my self which one to use. Fist I want to tell you about my set up. I am running a 350ci engine with Summit brand Vortec heads (175cc intake, 67cc combustion chamber), Weiand Vortec Street Warrior intake manifold, my TBI unit flows 620 CFM, 9 to 1 static compression, 1 5/8" headers with 2.5" collectors flow into a single 3" exhaust, 1800 RPM stall converter w/ lock up, 4L60E trans thats been modifications, 3.42 rear end gearing, and finally its going into a '94 Chevy K1500. Low end torque is important and I would also like to get decent fuel milage as well. I have 2 Lunati flat tapet Hyd. cams first one is an older single pattern grind from them that specs out to 268 ADV/218 @.050, 110 degrees LSA, and .457" of lift. The second one is a Voodoo cam that specs out to 256/262 ADV Dur, 213/219 @.050, .454/.468" of lift on a 112 deg LSA. I will be using a set of Lunati 1.5 full roller rockers on which ever cam is picked. I also purchased the recomended Lunati springs (same springs for both cams) for the build. I am leaning twards the Voodoo my self, but I am willing to use which everone comes out on top. Thanks
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-05-12 08:11 AM - Post#2255927
In response to navygunner08
if limited to only those two the lower intake duration and wider LSA of the voodoo cam seems the better choice
| " " IF YOU CAN'T SMOKE THE TIRES FROM A 60 MPH ROLLING START YOUR ENGINE NEEDS MORE WORK !" |
navygunner08
Loc: New London, CT
Reg: 02-13-11
08-05-12 10:57 AM - Post#2255985
In response to grumpyvette
Thanks Grumpy. I will use the Voodoo cam.
capricesport66
Loc: Lafayette, Louisiana
Reg: 11-02-03
08-05-12 12:48 PM - Post#2256033
Looking at flow numbers, I'd also pick the 213/219 camshaft.
Gerald
Lafayette, La.
http://www.flickr.com/photos/95648804@N08/
'66 Chevy Caprice 2DR HDTP 496/4L80e/3.73, 20's, Console, Buckets
'06 Chevy 2500HD 4x4 LBZ Duramax/Allison
'08 Toyota Highlander "Hybrid"
'99 VW Jetta TDI |
navygunner08
Loc: New London, CT
Reg: 02-13-11
08-05-12 01:25 PM - Post#2256043
In response to capricesport66
Where did you find flow #s for the heads? I have been looking and all I have is a very basic # from summit.
capricesport66
Reg: 11-02-03
08-05-12 01:31 PM - Post#2256044
http://static.summitracing.com/global/images/instr...
http://www.summitracing.com/parts/SUM-151124/?rty p...
Instructions sheet. Be sure these are the same heads.
Gerald
Lafayette, La.
'99 VW Jetta TDI |
capricesport66
Reg: 11-02-03
08-05-12 01:32 PM - Post#2256045
Or you can spend about $50 to have the heads flow checked somewhere locally. Atleast that's what it costs here in Louisiana to flow check 1 cylinder and both intake and exhaust.
Gerald
Lafayette, La.
'99 VW Jetta TDI |
navygunner08
Loc: New London, CT
Reg: 02-13-11
08-05-12 01:47 PM - Post#2256051
Thanks for the info. They must have added that spec sheet not too long ago.
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-05-12 02:04 PM - Post#2256063
