Username Post: 3 speed Manual Help needed        (Topic#285068)
NICE58DELRAY
NICE58DELRAY
Loc: Owatonna, MN
Reg: 07-25-11
08-03-12 08:18 PM - Post#2255496
Calling all 3 speed Manual Transmission Specialists!
I am replacing the 3 speed Manual Transmission in my 58 Delray with another date correct non syncro. I screwed up when I removed the side cover with the shift arms. I wanted to Inspect the shift forks for wear and didn't take the time to fully study the correct placement of the rear fork.
The rear fork is offset and I need to know which way. Is it offset to the front or the back. I also found out it is much easier to have the cover removed in order to tighten the 3/4 " Tranny to Bellhousing Bolts. I am at a standstill until I find out which is the correct placement. Also, correct me if I'm wrong but do both shift arms point down? I have a 3 speed Column Shifter.
Thanks!!
Grey
Loc: Norway
Reg: 08-02-05
08-04-12 12:09 AM - Post#2255536
    In response to NICE58DELRAY
The rear fork (first and reverse fork) is offset forward or with the "hump" toward the rear. Both levers point downwards.
1959 Chevrolet ElCamino
1959 Chevrolet Biscayne
1965 Pontiac Bonneville
Delray_58
Delray_58
Loc: Scotts Valley, CA
Reg: 03-20-10
08-04-12 07:15 AM - Post#2255581
    In response to Grey
Both shift arms point down, though they move depending on the gear you're in, of course.
'58 Delray 283 3-speed
In the family since new
Execution time: 0.057 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:01 AM
