Username Post: Replacement Sheet Metal Thickness        (Topic#284900)
rmsls1
rmsls1
Loc: Houston TX
Reg: 06-25-11
07-31-12 01:19 PM - Post#2254219
I need to do some patch work on fenders, quarters, and other areas. I have a 63 Impala SS. What gauge sheet metal should I use? I have been told 18 or 20 gauge.
1963 Chevy Impala SS with 875 trim code
1967 Triumph Spitfire
1970 El Camino
1984 Corvette with 4+3 manual trans.
sierra_5.3
sierra_5.3
Loc: South Louisiana
Reg: 03-29-07
07-31-12 02:40 PM - Post#2254238
    In response to rmsls1
18 is what I use on patch petal. The thicker the better in my book.
To walk a mile you have to start with a single step.
'66 Chevy C-10 Short Bed, Fleetside, Big Window. 383/700r4
'08 Chevy Silverado 2wd 1/2 ton Crewcab LS, Blue Granite
'11 Nissan Maxima SV, Pearl White
'65 Ford Mustang Coupe 289 w, 3spd
Sweed62
Reg: 10-24-04
08-01-12 11:08 AM - Post#2254528
I use original or thicker allways.
Im in europe, millimeters around here, My frame was 0.1", my rear qarters is 1 mm, i do believe floor is less than 1 mm at some places, i guess streched, then i use 1 mm anyway. Then some rocker parts was 1.5 mm. I try to measure at a not rusted area.
Svenne
Execution time: 0.075 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:59 AM
