Username Post: Leakdown Test        (Topic#284884)
57dood
Loc: Ontario
Reg: 08-11-05
07-30-12 10:53 PM - Post#2254057
Can someone verify.Homemade tester with regulator, guage,and quik connect hose to cylinder.
90 psi into cylinder TDC, compression stroke.car in gear emerg brake on.
5-10 % leak ,good motor.
30% plus ,major issues.
Air leak at tailpipe,bad exhaust valve.
Air from carb,leaky intake valve.
Air from pcv ,bad rings/cylinder.
Gitter Done,Cant drive 55
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
07-31-12 07:22 AM - Post#2254120
    In response to 57dood
looks good to me.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
57dood
Loc: Ontario
Reg: 08-11-05
07-31-12 11:59 AM - Post#2254200
    In response to 62chevy427
hmmmm
we pulled plugs from the stinky 350.it has a low mileage bottom end and all rebuilt cast,202 stainless valves,vitons,etc.ran about 200 miles.
2 plugs pulled so far are caked with heavy gunk.we put 90 psi in at tdc.air drops gradually to 10 psi.u can only hear air escaping inside base of intake but not thru carb?
any ideas.
07-31-12 02:26 PM - Post#2254231
Rings.
Leakdown tester numerical results will vary with details of the design.
I assume that you put an orifice between the regulator and the gauge?
57dood
Loc: Ontario
Reg: 08-11-05
07-31-12 03:40 PM - Post#2254258
    In response to Rick_L
too inacurate ,looking at a store bought tester before proceeding.
Execution time: 0.115 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:03 PM
