Username Post: A6 AC comprfessor seal ?        (Topic#284687)
rod
Loc: kingman,az
Reg: 04-29-00
07-26-12 08:00 PM - Post#2252531
my A6 is leaking out the front seal. it is just out of warnety. all new parts [now 1 yr old] and changed to 134.
i have a clutch tool.my ? is how do you get the seal out and back in.
i can get a seal for $24, whereas a reman A6 cost $200 + tax.
any help is appreciated
rod in AZ
Allan In NE
Reg: 12-27-11
07-27-12 07:22 AM - Post#2252633
    In response to rod
You'll still need the snapring tool and also the remove/install tool to latch onto that seal assembly and pull it out.
Allan
Lifelong GM automatic transmission specialist
kangaroo
Reg: 11-04-06
07-29-12 01:15 PM - Post#2253385
    In response to Allan In NE
I did not know you could replace the seal. I dont want to hijack you thread but since you asked i would like to know also. I have the other type compressor with r134 and the coolant is leaking at the pulley. Is there a seal to replace? Or do I need to buy a new compressor?
http://www.oreillyauto.com/site/c/detail/MRY0/57 22...
Edited by kangaroo on 07-29-12 01:16 PM. Reason for edit: No reason given.
Senior Chevytalk Moderator
07-29-12 03:14 PM - Post#2253429
    In response to kangaroo
My local rebuilder charged me $97 to change the seals. All of them, plus check the compressor. The bearing and stuff checked out. I put it back in and charged it up. It can blow down to 60 degrees on 100+ temp day! It's worth to have a shop change it if they do a complete compressor check. It was like buying a new compressor. Yes, mine is a R4 with a serpentine belt setup.
'96 GMC Jimmy LS
Execution time: 0.102 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:58 PM
