Username Post: Garage cleanout! More FREE stuff!!!        (Topic#284679)
Pauls56BelAir
Pauls56BelAir
Loc: Valley of the Sun
Reg: 05-30-04
07-26-12 03:17 PM - Post#2252460
Well the car's mostly done now, and I need to clean out the garage. So for only the cost of shipping, I'm offering ALL of the following parts to CT members:
Gauge set with bezels, fully operational with AAW harness, but rat-rod cosmetically.
(2) Deluxe heater control bezels with glass, rat rod chrome.
New Danchuk antenna bezel, also Accel coil and Accel dual-point distributor.
55-56 Belair horn ring, driver quality.
Original AM tube radio with fader knob.
Holley double-pumper feed, Edelbrock/Carter feed line.
Original 4-blade fan.
2 door sedan front window regulators (need rebuilt), an original bumper jack with baseplate and irons.
56 aluminum dash trim, ugly.
55-7 2 door sedan Belair stainless, right door only, nice shape.
56 Belair front fender stainless, 1 set upper and lower, polished.
I also have some unused window felts, driver quality inner and outer door handles and window cranks and some ugly emblems, an MSD 6AL box. I'll separate, just tried to get numerous things in each picture. Moving soon, need this stuff gone.
Call it long overdue payback for all the help over the years!
Paul Wallace
56 Bel Air 2dr Sedan 350/TKO 600
2000 Jeep Wrangler
9/11/2001 Never Forget.
Anything is possible if you don't know what you're talking about.
55 Shaker
55 Shaker
Loc: north central IL.
Reg: 03-13-06
07-26-12 05:16 PM - Post#2252490
    In response to Pauls56BelAir
Paul I'm interested. Sent you a private topic.
Brian
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-26-12 07:05 PM - Post#2252516
    In response to 55 Shaker
Brian, you're first in line for the speedometer/clock.
Everything else is still available!
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-26-12 07:23 PM - Post#2252523
Distributor spoken for...
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-26-12 09:29 PM - Post#2252557
One heater control bezel and the passenger door stainless spoken for.....
Paul Wallace
2000 Jeep Wrangler
Edited by Pauls56BelAir on 07-26-12 09:29 PM. Reason for edit: No reason given.
hep1966
hep1966
Loc: Lansdale, PA
Reg: 05-10-04
07-27-12 06:07 AM - Post#2252606
I could use the radio and dash trim parts if they're still available. Also antennae base, felts and regulators.
48 Jawa
56 210
66 Chevelle
96 C1500
07 Prius
10 CRV
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
07-27-12 07:35 AM - Post#2252641
May I be 2nd in line for the speedometer cluster...in the event that #1 changes his mind?
Reg: 08-16-05
07-27-12 07:36 AM - Post#2252643
Do you have the complete emergency brake assembly? Willing to pay.
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-27-12 08:31 AM - Post#2252662
    In response to larrybrowningmauldin
Radio spoken for.
Dash trim, door cranks and handles spoken for.
Larry, thanks for the interest, unfortunately you'd be fourth in line. Those went within minutes of posting the ad! No e-brake parts, sorry.
Paul Wallace
2000 Jeep Wrangler
cnbell
cnbell
Reg: 04-14-04
07-27-12 12:09 PM - Post#2252705
Hi Paul, I'd like the window regulators and jack if you still have them.
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-29-12 09:05 PM - Post#2253537
    In response to cnbell
My fiancee has spoken for the horn ring of all people!
Jack and regulators spoken for.
Still have the fender spears, carb fittings, fan blade and the bellhousing.
It's been crazy, I've had a tough time keeping everything tracked. I'll start getting shipping estimates for everyone getting parts on Wednesday.
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
07-31-12 09:14 AM - Post#2254152
MSD box spoken for....
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-01-12 02:17 PM - Post#2254597
Fender spears spoken for...
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-08-12 08:53 AM - Post#2257092
Found more stuff: a timing light, a dwell/points meter, and a new set of weld-on leaf spring perches. Will post pictures most likely tomorrow!
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-09-12 02:06 PM - Post#2257603
Timing light and dwell meter (will separate everything)
Weld on spring perches, Neal sandrail gas pedal.
Speedometer adapter, converts GM mechanical trans output to 3 wire electronic speedometer.
Also found my defroster duct, it's rust free.
Paul Wallace
2000 Jeep Wrangler
Edited by Pauls56BelAir on 08-09-12 02:07 PM. Reason for edit: No reason given.
swbatt
West Coast Show Support
swbatt
Reg: 03-25-01
08-09-12 07:32 PM - Post#2257723
Paul,
What bell housing do you have? I may be interested.
Thanks Junior
FiftiesMan
Loc: Washington, USA
Reg: 06-07-06
08-10-12 07:37 AM - Post#2257823
Paul,
I'm interested in the Dwell meter. If it's still available.
Thanks,
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-10-12 02:23 PM - Post#2257911
    In response to FiftiesMan
Junior, it's a stock 55-57 unit, the type that mounts the starter. I used it with a later-model block-mount starter 350.
Mike, all yours.
Also, spring perches and speedometer adapter spoken for!
Paul Wallace
2000 Jeep Wrangler
AB6DO
Loc: Near Fresno, Ca
Reg: 12-18-05
08-11-12 08:54 AM - Post#2258103
Sand rail gas pedal would look goof in my sand buggy
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-16-12 12:28 PM - Post#2259959
    In response to AB6DO
Ok, also found a Danchuk rear ebrake cable assembly for a stock drum brake rear, new in box.
AB6DO-- pedal is yours. Private topic sent!
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-16-12 01:11 PM - Post#2259966
Found unused black kick panel boards.
Paul Wallace
2000 Jeep Wrangler
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
08-16-12 02:48 PM - Post#2260006
E-brake cable and kick panels spoken for.
Thanks guys! I the fan, the defroster duct, and the timing light are still left.
Paul Wallace
2000 Jeep Wrangler
cnbell
cnbell
Reg: 04-14-04
08-17-12 12:05 PM - Post#2260307
Paul, I do need an E-brake cable, throw it in the box with the window regulator if it hasn't shipped yet...
Pauls56BelAir
Pauls56BelAir
Reg: 05-30-04
09-02-12 11:33 AM - Post#2265728
Hey everyone! So big apologies to everyone still waiting on parts, my move happened last weekend. We've been painting, unpacking, cleaning, and catching up on maintenance at a breakneck pace. My "honey-do" list is so long I can't see the end of it yet!
I should get back to the old house where the parts are at this Thursday, I'll make sending parts that I've received checks for top priority (just don't tell my fiancee that! )....
Down to the stocker fan, defroster duct, bellhousing (sorta), and the timing light.
Paul Wallace
2000 Jeep Wrangler
Edited by Pauls56BelAir on 09-02-12 11:33 AM. Reason for edit: No reason given.
Chevyfan60
Chevyfan60
Loc: Longmont, CO
Reg: 04-19-01
02-26-13 12:44 PM - Post#2320833
Hi Paul,
I can use a working timing light if you still have it. Let me know the cost of shipping to 80501. Thanks, Michael
Michael
1960 Impala 348, 1960 El Camino (x2), 1960 Nomad, 1992 S-10 Blazer, 2001 GMC Sierra 2500HD,
2002 Trailblazer
Execution time: 0.107 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 AM
