Username Post: please help.....clutch        (Topic#284514)
weldvair
Loc: st cloud fl
Reg: 09-14-11
07-23-12 01:02 PM - Post#2251245
I have installed the dash & petal assy from a 1959 El Camino in my 1965 Biscayne.
I bought the clutch (10 1/2") from NAPA. It's
the diaphram type.
It is very hard to depress & am wondering what the is the function of the heavy spring mounted on the side of the petal assy......Could it be the problem or something else. The spring seems to move very little when depressing the clutch.
DDonnie
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
07-23-12 04:52 PM - Post#2251358
    In response to weldvair
I've always wondered the same thing. The '59, '60 and '61 all have that same type spring and other than maybe some stability and a little spring power, I don't see what the real purpose is. What I do know is, it is not the easiest spring to take out. The '62 and newer cars went to a different design. Other than the Diaphram Pressure Plate itself, I'm wondering if you have the correct leverage applied with the non-original set up.
Bill
Member:
-National Impala Association
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
07-23-12 06:02 PM - Post#2251384
    In response to 62BillT
Its called an "over center spring", but I don't know what it does. I got mine from Jens, maybe he knows.
59 El Camino, 62 Bel Air SC, 62 Bel Air SC(sold in Finland is 2011), 63 SWC Vette (sold)
Member #2194
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
07-24-12 09:39 AM - Post#2251624
    In response to DonSSDD
The over-center spring is harder to push at first while the clutch is easier to push. As the pedal get to about half travel of its arc it is a straight pull so no effect on pedal pressure other than friction in the bushings. After that is pulls the pedal down lessening the amount of effort needed to push the cluth pedal down the rest of the way. Without that spring it's all leg power.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Grey
Loc: Norway
Reg: 08-02-05
07-24-12 10:29 AM - Post#2251649
    In response to f.i.57chevynut
It´s also adjustable although i believe the adjustment has to do with the "neutral" point and not tension strength.
1959 Chevrolet ElCamino
1959 Chevrolet Biscayne
1965 Pontiac Bonneville
weldvair
Loc: st cloud fl
Reg: 09-14-11
08-08-12 02:42 PM - Post#2257224
    In response to Grey
I found my problem......there was a misalignment
between the clutch pelal & the Zbar.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
08-16-12 06:46 AM - Post#2259874
the spring you're talking about does two things. it helps when it is over center to depress the clutch, then it holds the throwout bearing off the pressure plate when you let off the clutch. without this spring you would have no "free travel" causing the throwout bearing to fail prematurely.
Execution time: 0.074 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:10 AM
