Username Post: firewall plug        (Topic#284505)
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-23-12 10:02 AM - Post#2251197
Hi all.
Can someone give me a heads up on how to disconnect the plugs at the firewall for the engine harness, etc...
The plug is near the master cykinder, 1993 c1500 .
Thank you
GM fan FOREVER
07-23-12 11:06 AM - Post#2251216
    In response to rockfangd
On the driver's side it's got the single 1/4" headed screw in the middle. Unscrew it until you can hear/feel it "popping" - at that point it's fully unscrewed but the connector is still held together with some black, tarry water resistant goo. You can pull the connector away from the firewall at this point.
Just in case you need to do the passenger side one too it doesn't disconnect (electrically) at the firewall. You can remove two 7mm headed screws and the piece unhooks out of the firewall hole, but the actual ends of the connectors are inside the truck - at the PCM, and a couple others nearby, all reachable if you remove the glove box insert to access them.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-23-12 10:26 PM - Post#2251489
    In response to someotherguy
thank you very much for the reply. I will definately check and update in the morning. The second part you posted almost sounds like what I saw on the driver side. I dont recall seeing a screw in the center but I could very well be wrong.
again thanks
GM fan FOREVER
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
07-24-12 10:14 AM - Post#2251642
Its funny how we miss something simple like a solt in the center. I knew it was 3 plugs together as one but didnt even see the bolt. it came right off and I was able to disassemble the plugs
GM fan FOREVER
Execution time: 0.424 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:06 PM
